I have a 2000 Nissan Patrol 4wd with a manual g/box and transfer case. The transfer case has a chain drive to the front drive shaft. Auto hubs on the front hubs.
It needs a less viscous, lighter oil. A heavier oil will cause the front output shift to turn even when in 2wd and the autohubs will engage which is not wanted.
Currently running Castrol transmax Z synthetic atf in it.
Have recently put penrite pro gear 70w/75 synthetic gl4 gear oil in it.
They have the same viscosity at 40° and 100°c.
Will the 70w75 gear oil offer any wear advantage ?
PRO GEAR 70W-75 (Full Syn.) | Penrite Oil
Pro Gear 70W-75 is a premium full synthetic, high performance oil manufactured from a blend of synthetic base oils including ester. It uses the latest technology, purpose designed additives for long service life and meets the performance requirements of API GL-4 Plus as well as many other...
penriteoil.com.au
Colour | Amber |
Density at 15°C, kg/L | 0.874 |
Viscosity, Kinematic, cSt at 40°C | 38 |
Viscosity, Kinematic, cSt at 100°C | 7.5 |
Viscosity Index | 177 |
Zinc, Mass % | 0.131 |
Viscosity, Brookfield at -55°C | 109,680 |
