I've been doing some thinking/reading about ATF recently and came across the following info. I'm not up on the operating temps of ATs and ATF so could you guys comment on if you think this is correct?
Also what is the normal temp an auto. transmission operates at?
"At 200 degrees, the transmission fluid will last 100,000 miles
At 220 degrees, the transmission fluid will last 50,000 miles
At 240 degrees, the transmission fluid will last 10,000 miles, varnish forms.
At 260 degrees, the transmission fluid will last 5,000 miles, seals harden.
At 295 degrees, the transmission fluid will last 1,500 miles, plates slip.
At 315 degrees, the transmission fluid will last 800 miles, fluid turns to tar."
Thanks,
Paul
Thanks,
Paul
