ATF for 2016 Ford Focus AT transmission?
Los Gatos, CA
My friend's 2016 Focus has 130K and has never been serviced.
I guess it takes Dual Clutch fluid?
Can I use Motul or Valvoline? 2 quart capacity? Any tips are appreciated.
I have a 2017 with the dual clutch transmission. Rock Auto had the OEM Motor craft DCT fluid for ~26$ a quart last time I checked. Only need 1.7 quarts, so I went with OEM. I also hear there is a GM syncromesh friction modified fluid that is good for higher mileage vehicles. Mines gets an occasional gear grinding downshifting to second, so I will use that fluid next change.
You can use any brand DCT fluid that has the relevant standard on it, which I think for your car is M2C200-D2 :unsure:
The best price I could find is this Mag1 by the case of 6
If you're willing to buy 12 bottles at a time, there's Amalie DCT
