This is for a NC Miata auto-trans (actually it's for a Fiat 124 Abarth but it uses the NC transmission in a different housing).
Redline is not listed here but I believe the D4 ATF is compatible according to their site. Which fluid would you pick if the car will be autocross and tracked every month. An ATF cooler might eventually be installed if temperature becomes a real problem. Fluid will be changed annually and car has 45k miles on it today.
This what RockAuto lists as compatible.
