ATF confusion
Apple Valley, California
I want to change the ATF in my girlfriends 04 Chevy Tahoe.
I seem to remember that it uses Dexron V. Went to A-Zone and had them look it up. The puter says Dex VI.
Reading the back of the bottles......DexV and DexVI will replace DexII and DexIII but the DexII and DexIII wont replace the DexV or DexVI.
I personally wont own a car with an AT so I'm out of the ATF loop. I bought the DexVI but is this the correct fluid?
I just want the correct fluid. No Amsoil or Mobil 1. Just the Warren made stuff is fine but which one?
That would be a DEX-III transmission, wouldn't it?
DEX-III is now an 'outdated' spec, having been replaced by DEX-VI, but if you want simple/cheap, just grab some DEX-III.
I've never heard of Dexron V. Maybe you meant MERCON V?
Either way, the factory fill for that was Dexron III, and Dexron VI is the current specification for that fluid. You can use that fluid in place of Dexron III, but not the other way around. Just like you can put ATF+4 in a Chrysler calling for ATF+3, but not the other way around. Just like you can put DW-1 in a Honda calling for Z-1, but not the other way around.
The bottles say. "Dexron/Mercon-V". Last time I owned an AT it used type-F.
DexVI is the latest and greatest Dex (not cheap). Just go to Wal-Mart and get the Maxlife ATF...it's about $14 a gallon.
Originally Posted By: brandini
Check the manual
Don't have one. Never have figured out how to turn the stupid headlights off at the drive in.....But thats another thread
DEX VI will trump previous fluid, IE even if your chevy calls for DEX V Dex VI can be used as well. If you want to save money go with DEX V but for a better fluid use the DEX VI
The trans originally called for Dex III, so you can obviously use that. Dex VI supersedes Dex III, so you can use that too. Either one will work fine.
Just a suggestion....since they no longer make Dex III and you don't want to use Mobil 1, many posters have been buying Valvoline MaxLife Dexron/Mercon to use. Dex III is now obsolete and if you want to use the current ATF at the lowest price Walmart has Dex VI in the SuperTech brand.
Search the ATF section of the board to see that they have been using the MaxLife and if they are happy with the product.
IMO....You can get a great deal on it by buying it at Advance Auto, using one of the discount codes, and picking it up at the local Advance Auto.
I purchased Mobil 1 from Advance Auto, using the discount codes for the ATF, got each quart for about $5.25. I also purchased Mobil 1, synthetic gear lube, using the discount codes and got a great deal.
Just my opinions....look up to find what you want to use in your transmission.
I did not know this. Thanks.
There are no advanced auto stores in Ca. I hear alot about Advanced auto though.
Check the manual
Id like to know how to turn the lights off when Im parked, the automatic lights-on thing is a pain.
Check the manual
Only way I have found is to take the battery cable off.
If it's your daylight running lights...try pushing your dome light button several times until they shut off.
From Amsoil Don't know what engine you have? So I just put in the 5.3 Litre.
Good info for capacities etc.
2004 CHEVROLET TRUCKS TAHOE 5.3L 8-cyl Engine Code [Z] Flex-fuel
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*[1]
Maximum Performance Signature Series 100% Synthetic 0w30 Motor Oil (AZOQT)
Maximum Performance SAE 5w30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5w30 Synthetic Motor Oil (XLFQT)
Performance Synthetic 5W30 OE Motor Oil (OEFQT)
All TEMPS......5w30 [2]
Automatic Transmission,4L60-E......AF6 [3]
Low Viscosity Synthetic ATF (ATLQT)
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Synthetic Tractor Hydraulic/Transmission Fluid (ATHQT)
Differential, Rear W/ 9.50 RG......GL-5
All TEMPS......75W-90 [4]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Differential, Rear W/ 8.60 RG......GL-5
Differential, Rear W/ 11.50 RG......GL-5
Differential, Rear W/ 10.50 RG......GL-5
Differential, Front Selectable 4WD......GL-5
All TEMPS......80W-90
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Transfer Case,BW 4481......GLS [5]
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Transfer Case,NVG 246......SLF [6]
No AMSOIL Product Recommendation
Transfer Case,BW 4482......GLS [5]
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
[1] If using E85 or M85 fuel, use AMSOIL oil of the appropriate
viscosity for the OEM recommended drain interval. If E85
or M85 fuel is not used, use AMSOIL oil of the appropriate
viscosity and the extended drain interval recommended
for that oil.
[2] SAE 5w30 is preferred.
[3] This specification has been updated from Dexron II or III to
Dexron VI per a Technical Service Bulletin from the
manufacturer
[4] Synthetic lubricant, GM part no. 12378261,
or equivalent product formulated to meet
GM specification 9986115.
[5] GM recommends Part No. 88861800 (Canada 88861801)
or equivalent for manual transmission, transfer
case applications.
[6] GM part no. 12378508 (U.S.), 10953626 (CAN)
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (Ea15k32)
Oil Filter WIX 51042 Oil Filter
Air Filter Absolute Efficiency Air Filter (EAA123) [1]
Air Filter Absolute Efficiency Air Filter (EAA123) [2]
Air Filter WIX 42488 Air Filter [1]
Air Filter WIX 42487 Air Filter [2]
Fuel Filter WIX 33623 Fuel Filter
Transmission Filter WIX 58904 Trans Filter [3]
Transmission Filter WIX 58847 Auto Tran Filter [4]
Transmission Filter WIX 58608 Auto Tran Filter [5]
[1] Heavy Duty Version
[2] Light Duty Version
[3] 4L60E - Shallow Pan
[4] 4L60E - Deep Pan
[5] 4L80E - Deep Pan
NGK PLUGS AND WIRESETS:
GPSERIES PLUG TR5GP
IXIRIDIUM PLUG TR5IX NGK7397
PREMIUMIRIDIUM PLUG ITR5F13 ^
PREMIUMPLATINUM PLUG PTR5D-10 *
VPOWER PLUG TR5 NGK2238
WIRESET WIRESET RC-GMX091 NGK51033 [1]
WIRESET WIRESET RC-GMX102 NGK51430 [2]
[1] 10.5 leads
[2] "Use w/Coils Stamped 19005218 (9.2"" Leads)"
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T221 T221 T161
NeoForm T16220 T16220 T16160
Winter T37225 T37225 T37160
CHASSIS LUBRICATION:
2WD
6 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR)
4WD
11 Fittings, 0 Plugs..........LB
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........16 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4L60-E Initial Fill..........5 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.3 quarts
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.2 pints
Differential, With 10.50 RingGear Rear..........5.5 pints
Differential, With 11.50 RingGear Rear..........7.7 pints
Differential, With 8.60 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Transfer Case, NVG 246..........4.1 pints
Transfer Case, BW 4482..........3 pints
Transfer Case, BW 4481..........3 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....18 ft/lbs
Transfer Case NP8
Fill Plug 15 ft/lbs
Drain Plug 15 ft/lbs
Transfer Case NR3, NR4
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
Transfer Case NVG263-NP1
Fill Plug 15 ft/lbs
Transfer Case NVG261-NP2
Fill Plug 15 ft/lbs
Transfer Case NVG246-NP8
Fill Plug 15 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Product Recommendations and Drain Interval Chart
Tried that, tried setting the parking brake etc... Nothing works. GM didn't have drive in movies in mind when they built this truck.
Anyway back to the ATF. I took the upper trans cooler line off the Radiator, put a hose on the line, aimed it at a bucket and had GF start the truck.
Suddenly I had ATF everywhere! After shutting the truck off I determined that on this truck the ATF pumps from the bottom of the cooler and out the top!
It's plummed opposite of every other car I have worked on.
So after disconnecting the lower line and putting a hose on it I had her start it and pumped 3 qts out. So I put 3qts in the dipstick hole and repeated it.
Did this 3x. I'm hoping that I got most of the old fluid out.
Reason #43456784 that I only drive stick shifts.
