Auto tranny clutches are engaged with hydraulic clutches. As these clutches wear the worn particles either stay in the fluid or are filtered out. The transmission fluid is darkened by those clutch particles still in suspension. As time goes by the fluid is to some extent subject to shearing. The more it is sheared the more likely there is to be less pressure, which will mean more clutch wear and darker fluid. It is my contention that draining the tranny pan and refilling with fresh fluid will remove some portion of the worn clutch particles and increase the viscosity of the transmission fluid. This will keep the pressures high and reduce clutch wear. All of this should greatly increase the lifespan of the tranny. So, I believe just swapping fluid periodically is nearly as good as dropping the pan and changing fluid and filter, and is a lot easier and cheaper. Anyone agree or disagree???
