- Joined
- Aug 27, 2020
- Messages
- 37
Does putting car into P or N at red lights help extend auto transmission life? '10 Sonata 2.4 original owner 374 k. I don't accelerate hard at all, come to complete stop before R to D.
Don't really know the answer, but I bang the trans into neutral and take my foot off the brake pedal at almost every stop light (on level ground). Haven't changed a brake light bulb in many years if that helpsDoes putting car into P or N at red lights help extend auto transmission life?
All your actions would do is wear out your linkage.Does putting car into P or N at red lights help extend auto transmission life? '10 Sonata 2.4 original owner 374 k. I don't accelerate hard at all, come to complete stop before R to D.
This is valid, but even more concerning: what are you going to do when you look in rear view and see cars flying side to side from a runaway semi, and you panic and hit the gas… and bang the rev limiter in neutral as you get plowed from behind??They are made to stay in gear
What will happen if you pop it in reverse and hit the gas ?
That will cost you
Mistakes happen
Keep her in D
There are a few lights around here where I end up waiting 5 minutes. I will put it in park then. Especially on the 2011, F150, which has "accelerated" a bit on its own while stopped in D, a few times. The 5 minute light happens when I'm the only vehicle on the sensor, as it won't give a green left turn arrow for just one vehicle. But when others show up, the green left turn happens next cycle.
In the McDonald's drive through one day, the 2011 started moving forward, so I put my foot harder on the brake. The brakes actually groaned a little under the strain, and I looked at my foot to make sure it was not on the gas pedal. It wasn't. I shut the thing off, restarted and it didn't happen again for quite some time. Over the last 12 years, it's happened a handful of times. Tach goes to 1500, and it will happen in Park too.
Yes, correct. It's the 6 speed and 3.5L EB engine. About 150K miles now, the transmission does occasionally gag too. Mostly on cold startup, where it stays in 3rd gear and won't shift up or down.6R80 in your 11 F150?
That's a long shot, tow trucks pull cars in Park all the time. The tires slip. Besides, you've got someone to sue if that happens.If you get rear ended while in Park, it can damage the Park mechanism, so leave it in gear with the brake on.
