This post is related to my other thread re MDX trailing arm bushings but is a more general question. How do you know when to replace a suspension rubber bushing? When I replaced the dog bone strut on my 99 Avalon it was easy...the radial rubber ligaments where torn all the way through. But what about superficial cracking or very small tears? Do rubber bushings tend to fail quickly after they start to crack or can they last for years with minor cracks? This article does not mention superficial cracks. It talks only about bushing failures which cause handling problems and noise.
https://www.generalspringkc.com/how_to_tell_if_suspension_bushes_worn_s/3151.htm
Here is another good discussion which says almost any rubber bushing over 5 years old will start to check and is normal.
http://www.city-data.com/forum/automotive/2479092-cracked-control-arm-bushings.html
