Yes it’s “molecules spacing” for sure.Just do the experiment. Some funnels come with a screen in them, or use a paint filter, start with a low viscosity like water. Then use some nice thick gear oil. Then come back here and tell me which flows better through a fine mesh screen. I think its more the Molecules spacing than what their size is, when talking viscosity. Maybe others that are more knowledgeable can touch on that.
What does GD&T have to do with this discussion?For those claiming the ever tighter and tighter tolerances, do you know what GD&T is?
I'm the one who always messes that up between tolerances and clearances LOL. I am grateful that we have the great mind here to help me remember that there is a difference.I think that's referring to "Clearances."
http://www.epi-eng.com/mechanical_engineering_basics/clearance_and_tolerance.htm
This gets into my current field of study, Physical Chemistry.Just do the experiment. Some funnels come with a screen in them, or use a paint filter, start with a low viscosity like water. Then use some nice thick gear oil. Then come back here and tell me which flows better through a fine mesh screen. I think its more the Molecules spacing than what their size is, when talking viscosity. Maybe others that are more knowledgeable can touch on that.
Once again: Both. This is normal in almost all industries, when I was in metal stampings, the push was always to have machining tolerances at stamped metal prices. Computer memory is another example..
If the journal bearing has a clearance of 0.0019 inch, and if the journal was centered (the best it can do while turning), then the running clearance would be a max of 0.0019 inch/2 = 0.00095 inch. A running journal bearing can have a pretty small MOFT, like around 5-20 microns. The MOFT is minimized where the max loads are going through the rod due to combustion and inertial directional changes. Anyway, if the additives molecule size is around 0.4 microns, then it's still about 5μ/0.4μ = 12.5 times smaller than the minimum clearance if the MOFT gets down to 5μ. Your 4.750 times larger clearance than the molecules seems off.This gets into my current field of study, Physical Chemistry.
Paraffinic molecules (Group II, III, PAO, etc) average about 5 nanometers in size, or ~ 0.0000002 inches, or 0.2 micro inches or 0.2 millionths of an inch.
Additives such as ZDDP may range up to 10 nanometers in size or ~ 0.0000004 inches, , or 0.4 micro inches.
In summary, engine oil molecules, with their nanometer sizes, will pass freely through bearing clearances of say, 0.0019 inches, which is the middle spec for my Nissan 4.0L engine's main bearing Clearances. Those bearing clearances are therefor ~ 4.750 times larger than the average engine oil molecule.
Maybe it's late but 0.0019 inches bearing clearance/0.4X10-6 inches molecular size = a ratio of 4,750.If the journal bearing has a clearance of 0.0019 inch, and if the journal was centered (the best it can do while turning), then the running clearance would be a max of 0.0019 inch/2 = 0.00095 inch. A running journal bearing can have a pretty small MOFT, like around 5-20 microns. The MOFT is minimized where the max loads are going through the rod due to combustion and inertial directional changes. Anyway, if the additives molecule size is around 0.4 microns, then it's still about 5μ/0.4μ = 12.5 times smaller than the minimum clearance if the MOFT gets down to 5μ. Your 4.750 times larger clearance than the molecules seems off.
Your original post said 4.750, not 4,750.Maybe it's late but 0.0019 inches bearing clearance/0.4X10-6 inches molecular size = a ratio of 4,750.
Well, I thought it said it was a ratio of 4,750, with a comma.Your original post said 4.750, not 4,750.
Plus, the bearing clearance called out in service manuals is the total clearance (delta between journal OD and bearing ID), not the running clearance with the journal centered in the bearing, as explained earlier.
I'm just pointing out that the more realistic comparison of molecule size to bearing clearances is to compare the molecule size to the actual running MOFT clearance in the bearing. Bearings don't exhibit the full shop manual clearance (journal OD vs bearing ID) when they are operating. The actual running clearance can be in the 5 to 20 micron range, which would be 0.000197 to 0.000787 inch. So if the molecule was 0.0000004 inch, the size ratio in an operating journal bearing could actually be as low as 0.000197/0.0000004 = 493, which is much less than 4,750. But even with a minimum MOFT clearace, the molecule is still way smaller than the running MOFT.I am not not sure what we are debating here. When you measure the bearing clearance with say a Plastigage, you are measuring the distance between the journal surface and the bearing surface (as per the manual for general over hall procedures). That distance was compared to the size of a formulated engine oil molecule, nothing more, nothing less, in order to show the magnitude of the difference.
Good point.The 2019 Toyota 4 cylinder in my signature can use any oil from 0W-16 to 15W-40 depending on which country your operator manual was written in. According to Toyota.
The discussion is about tolerances and clearances isn't it?What does GD&T have to do with this discussion?
Here is some info that may provide some Background:What does GD&T have to do with this discussion?
Its proof of concept of flow through a screen. Isn't gravity one of the methods to test viscosity, you know the ball drop in the tube?Gravity is not a positive displacement oil pump.![]()
