- Joined
- Dec 16, 2022
- Messages
- 1,379
I just watched this video:
Basically he says one of the challenges of a hybrid engine is that temps don't get hot enough to burn off any water that might be accumulating in the oil.
In my daily drives, I frequently "get up to temp" but for my truck the coolant hits 85C and the oil hits about 90 to 93. When I'm towing, I'll sit around 100 to 105, sometimes hitting 110 peak up a hill in the summer, but usually hanging out around 105.
But 95% of my driving I probably only hit 90-ish.
This is lower than stock as I've swapped in a cooler thermostat to keep the temps lower while cooling.
Am I actually hurting things with this thermostat? On stock I'd regularly hit 105C empty and 115 to 120 towing up a grade.
