Quote:
Old cars don't nickle and dime you to death, they hour and day you to death with the inconvenience of more frequent repairs and the subsequent loss of use of the vehicle.
Quote:
This is usually the killer. It's not everyone who will actually rent a car for a week so that they can get their 18 year old car serviced/repaired.
Quote:
Keeping two cars works great for this. One to tinker with and one to drive
Quote:
In my case, I go through 2 or 3, maybe even 4 engines before I sell, crash or junk my cars. However they are all high boost, turbocharged monsters. Probably twice as many transmissions too.
Chris
Quote:
You can try to keep a car running forever. I typically drive mine to about 150k. It's not that they nickle and dime you after a while. It's almost always cheaper to repair them than replace them. Eventually the loss of reliability is what drives even frugal people to replace cars. Old cars don't nickle and dime you to death, they hour and day you to death with the inconvenience of more frequent repairs and the subsequent loss of use of the vehicle.
Quote:
That's one of the best paragraphs I've ever read on these boards. Made me stop lurking and sign up! Well spoken, Big Al.
Quote:
Thanks, LouDawg!
Quote:
Quote:
Thanks, LouDawg!
Hey, I'll be up your way tomorrow...I work for IPL and have a meeting in Indy.
Quote:
Quote:
MOST engines will outlast the car with reasonable care. Unless you own something that calls for synthetic, like a super high performance engine engine or a known sludger, conventional oil changed on a reasonable schedule will do just fine. I have opened up engines with over 100k on them, maintained on conventional oil, that looked spotless inside . . . and that was with oil that is not nearly as good as what we have now.
If you run a thinner oil for better fuel economy or do really long extended drain intervals, you might be able to justify synthetic. Otherwise, it's probably a waste of money.
I have seen engines that failed prematurely from blown gaskets, cracked heads, burned valves, broken timing belts, broken water pump belts, loss of coolant, frozen coolant, etc. Synthetic oil wouldn't have helped them. If you see one that's just plain worn out, it was probably badly neglected.
Excellent post, IMHO.
