Bob, your link in dead.
Microns.... most don't understand the smallness of the micron reference. BTW micron symbol is alt+0181 on your keyboard in case you want to use it.
Bacteria: 2 micron
Red blood: 8 micron
White blood cells: 25 micron
A micron is .000039 inches or 39 Millionth of an inch. What's the nominal clearance of rod bearings?
I see a lot of filters on sites that are usually nominal 19 to nominal 25.
They are full flow and they don't do too bad a job of helping to keep the oil clean.
At the winery where I work, we are concerned with keeping yeast out of wine that is to be bottled with residual sugar. Don't want some wine to go through a secondary fermentation in the bottle and make it cloudy or fizzy, so we use a membrane filter with an absolute value of 0.45µ That takes care of bacteria as well
I can appreciate less than 1 micron filtering, but it might be just a bit excessive. Yes there has/have been studies on micron rating and how it affect wear, so there is really a basis of real information and not "guesses".
SAE testing on a Detroit Diesel (General Motors AC Delco Division) showed an 8x factor at 1µ. But you do get 5x to 6x (times) normal engine life expectancy at 10µ and below.
Now, decide where is your point where you want to save money and where you expect to either retire, or sell the auto you are driving. Is it at 200,000 miles, or maybe 300,000 mile? Only you can venture that guess.
I bought a used 1996 Buick Park Avenue with 147,000 miles on it and everything on it works great.. everything.. and for $1500.00. I want a bypass filter just because (1) I'm a tinkerer, and (2) I want the engine to wear the least amount it can while I have it in my possession these next few years. Keeping the bearings and rings good will keep fuel economy better and oil consumption down, along with any major engine parts replacement.
I live in Michigan. Land of rusty cars. I should do a photo montage sometime with all the rusty framed cars I see at parking lots. I'm not worried about my '96 Buick making 300,000 on this motor, I'm more worried about the rust on the brake lines, rocker panel, underneath bolts, etc. Therein lies my biggest obstacle, not the micron size of oil contamination
Lots of good bypass filters and lots of great oils out there.
BTW I really preferred the old oil bath air filters I remember when I was young. They were messy, but I really think that oil captures more dirt than any throw-away paper element.
