I removed the chain to blow out the sprocket area and didn't pay attention when putting it back on. Now it barely nicks a branch so assume I must have put it on backwards. Are these blades actually directional? Are they marked somewhere?
The chain is absolutely directional. Looking at the photo below, if this depicts the chain sitting on the top edge of the bar, the tip of the bar would be towards the right side with the labeled cutter tooth closest to the bar tip.I removed the chain to blow out the sprocket area and didn't pay attention when putting it back on. Now it barely nicks a branch so assume I must have put it on backwards. Are these blades actually directional? Are they marked somewhere?
Chain saw chains are directional, but the blade itself is not. You don't really need to clean the sprocket out IMO unless something is wrong...I removed the chain to blow out the sprocket area and didn't pay attention when putting it back on. Now it barely nicks a branch so assume I must have put it on backwards. Are these blades actually directional? Are they marked somewhere?
Totally Bass Ackwards!
Flip the chain around. The other thing you will need to do is properly tension the chain. Rule of thumb I use is to pull the chain down in the middle of the bar and make sure the link is still engaged. As the chain warms up it will tighten up, so checking after some cutting is probably best. A chain that is too loose can come off, a chain that is too tight is hard on the drive.
Make sure you don't put the bar on upside down either..................OK I'll reverse it. The chain I mean.
Now that's just mean, LOL.Make sure you don't put the bar on upside down either..................![]()
Atikovi, he is just yanking your chain!!Make sure you don't put the bar on upside down either..................![]()
This is the way I was taught..."Cutter" could be "Cutting link"The chain is absolutely directional. Looking at the photo below, if this depicts the chain sitting on the top edge of the bar, the tip of the bar would be towards the right side with the labeled cutter tooth closest to the bar tip.
