See that my old thread's been revived. My Acura CL trans still holds ok currently 5,000km on Amsoil Universal ATF shifts rough only when pushed harder, but then under wot 9-out-of-10 smooth.
I recently read that in theese transmissions hard shifts mean shorter clutch engaging times thereby less clutch wear.
What say you? I am quite bamboozeled by this from Acura TL board:
" Road Rage03-09-2006, 7:42 PM
RR, would you please explain this. I'm not a 5AT guy, but this is interesting. Why would a harder shift result in less wear ? I thought the reverse would be true as a hard shift would result in more drive line shock therefore causing more wear.
It has to do with slippage, just as in a flywheel/clutch in the drivetrain. For all intents and purposes, two surfaces "locked" have no wear. So a clutch could last forever. But it is the engaging of the clutch where the friction materials on the clutch and flywheel rub against one another that the wear occurs.
An AT has clutches - lots of them. When they engage "soft", such as to provide a Lexus-like, buttery smooth shift, the surfaces are sliding against one another more than when the shift is "hard". A hard shift results in less frictional and abrasive wear. Try rubbing your palms together quickly - got it?
So all things being equal, the harder the shift, the less the wear. That is the basis for Amsoil's response.
Xpditor
http://tl.acurazine.com/forums/archive/index.php/t-89064.html
and here's the link
