I, too, used to be among the Xw-20 haters. However, after being on this board for quite a while and eventually having made the switch, I have no problems using it now IN VEHICLES WHICH THE MANUFACTURER SPEC'S IT. As stated, what is the problem in using a shear stable -20 weight vs. a not so stable -30 weight?
It should be common knowledge by now that the main reason for making the switch was probably due to CAFE, not any magical new engine building technology. On that same note, engines are now designed, engineered, and built to much higher standards, and the auto manufacturers probably realized that a lighter weight oil could be safely used. It's not that the engine was specifically designed to be used with a -20 weight, but that it will run fine on a -20 weight. They are getting the best of both worlds: meeting the lubrication/protection needs of their engines, while at the same time increasing the MPG ratings. The best of both worlds, and all they had to do was change the "3" to a "2"!
Most UOA's done on -20 weights have been very good. Of course, there are a few exceptions, and those seem to be from use in engines that weren't designated to be using a -20 weight in the first place. From what I've seen, Motorcraft 5w-20, Mobil 1 0w-20, Castrol GTX 5w-20, and Pennzoil 5w-20 have consistently been some of the best built and highly regarded oils on this site. If you're engine calls for a -20 weight, then use it and sleep easy at night. You have plenty of solid oils to choose from. If it doesn't call for a -20 weight, don't use it and sleep easy at night. Let's just puh-leeeease stop saying that -20 weights are no good and shouldn't be used under any circumstance.
[ May 28, 2004, 02:13 AM: Message edited by: ZiTS ]
