The picture is a 1 1/2 inch galvanized pipe elbow installed in 1970. The blockage is a solid chunk of rust that closed off most of the pipe. I could never figure why the bathtub drained so slowly
Anyhow the old pipe was cut out with a sawzall and replaced with Fernco fittings and PVC. That setup will outlive me. Anyhow, if your home or rental has galvanized water or drain pipe and you are getting low or no flow for some reason, the problem may be rust.
Thanks for reading.
Thanks for reading.
