Nikola,
Have in mind that many of the online technical data sheets haven`t been revised for some time(especially those offered by online shops)-always look for a "revision date" at the bottom.And this still cannot guarantee that the data is 100%correct,as sometimes the`d correct the physical properties,and neglect the certifications...
You can even bump onto tds of some 5w-40 oils dating 10+years back that were PAO back then(now Gr.III).
Look at this pdf:
http://www.liqui-moly.de/liquimoly/medie...%200w-40_EN.pdf
API SJ/CF
SH/EC/CF
ACEA A3-98/B3-98
MB 229.1
However,the description of the same oil on the same site says:
ACEA A3-04/B4-04 ; API SM/CF
LIQUI MOLY advise this product for vehicles with the following specifications: BMW Longlife-98 ; Opel GM-LL-B025 ; MB 229.3 ; Porsche ; VW 502.00 / 505.00
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/e_1360.html
..see what I mean? There are numerous examples like this.
Secondly,the ACEA combined the A and B categories several years ago(2004) and introduced some new-whether they changed the pass/fail limits I do not know(regarding A3,B3and B4 cats),but probably you could find the older ACEA specs and make a comparison...
http://www.acea.be/images/uploads/files/20090105_081211_ACEA_Oil_Sequences_Final.pdf
I think I have them somewhere,but not sure.
I am also not aware if there is any time limits concerning the ACEA categories(I know there is "expiry dates" on some OEM ones and the company has to apply again)...
So the most recent data you get from the label on the product-then check the oil company site-and don`t trust that much the oil stores online documents.
Regarding Ford categories-they keep to Gr.III oils -more here:
http://www.atiel.org/members/pdf_files/ACEA Stow.pdf
...what has always puzzled me is that they recommended 30weight HTHS3,5cPa...but that`s Ford...
Well,I hope this helps.
