Originally Posted By: Touring5
It may be different, but on a '87 Century with the 3.8l V-6, using the Mityvac was a bad experience. I think the dipstick tube makes a sharp bend and has a rather sharp edge. I could feel that resistance when inserting the plastic suction line. When I tried to remove the line it wouldn't budge. It took a good bit of finessing (rotate, push/pull gently) to finally get it out.
I notice that even one year to the next they changed dipsticks and tubes for some reson, its the same block.
The plastic part with the 0-ring broke on mine and i figured just get one from the yard, it turned out to be a fiasco and i ended up buying one from the dealer.
Mine has a straight shot right down to the pan but some of them seem angled and use a different stick. It seems to hang on the windage tray/gasket plate.
