Anyone here still using 15w40?
I use the dual rated Chevron 15-40 for my FIL mercury 60 hp outboard. Mercury wants 25w40 conventional that is rather pricey. I know the Chevron isnt rated for Marine use but it gets changed every fall when the boat comes out.
Just looked up what the newer gm 3.0 duramax calls for as I recently heard it's well known for oil consumption. It calls for 0w20 diesel oil. That's a bit of a jump from 10w30 though.
True, and there's Youtube videos on the subject. I just bought 3 jugs of Mobil Delvac 10W30 FA-4 just in case I have to do an oil change on a 3.0 Duramax. FA-4 5w30 and 10w30s are a baby step above the SAE 20 grade.
Manufactures can recommend whatever grade they want for whatever reason. I believe that the XW20 and XW30 grades are fuel economy driven. Personally I'm not interested in a 1.5% fuel economy improvment at the risk of increased wear and/or oil consumption that can't be good for downstream emission control equipment and sensors.
Pails of 15w40 are the best bang for the buck for use in everything IMO in ambient temperatures above freezing. Below that I move down to 10W/5W and 0W40 depending where the vehicle is operated.
Case in point, 10W40 GTX API SP in a 2022 3.6L Acadia that is operated on the west coast between Whistler and Vancouver and will never see colder than -20C.
If I owned a 3.0L Duramax, it would get 15w40 in the summer and XW40 in the winter.
Does that make me a "thickie"? No, because I'm not using redundant thick engine oils like 20w50 except in a JD lawn tractor.
When I start using it for snow blowing and I have the attachment, I'll use a XW40 appropriate for winter use.
And not really an HDEO application. It’s more of a PCEO application much like Euro diesel rated oils.
I’m more so referring to class 6-8 truck engines and off road/marine engines - so 7L to 32 cylinder. Etc.
If anything consumption has gone down in my opinion.
15w40 for 6.4 Powestrokes and ATVs as well as the generators/ mowers
5 gallon buckets
First choice Lucas Magnum
Second choice Mystyk
Third Delo
No, 10W30 has become the norm during the last decade.
After following this discussion, I became curious enough that I took an informal inventory of 15w40 and 10w30 at the local Walmart. It isn't even a competition. There must be 7-8 times as much 15w40 as there is 10w30. And 2-3 times more variety. 15w40 has it's very own section on the motor oil aisle, while I had to hunt down the 10w30, hidden amongst the other viscosities and brands. 15w40 is available in 1 gal. jugs, 2.5 gal. jugs, and 5 gallon pails. 10w30 is available in 5 quart jugs. (I didn't waist time looking at what is available in quarts, as it seemed that only VW/Audi and such would be buying diesel motor oil in quarts.)
Your market may be different. But if Walmart is any indicator of what the DIY'er is using for diesel engine oil changes here in Northern Utah, 15w40 is king of the hill.
Still use it in a lot of farm equipment and OTR trucks. A fleet I maintain uses it almost exclusively in anything from lawn mowers to forklifts to OTR trucks. Forklifts with Mazda, Nissan, and Mitsubishi engines will run 10-20k hours and we ran an old Cat with a Peugeot engine to 45,000 hours.
People use it because its 1. readily available nearly anywhere and 2. it simply works.
It’s still used extensively in agriculture, the farm I used to work at put 15-40 in everything from cars to combines, boats, small engines etc. Temps ranged from 0/110f never had an issue with anything but we changed the oil meticulously 3k or sooner
I noticed Lucas has two offerings in 15w40, Magnum and synthetic; I had no idea they had both.
Yes they even offer a FA-4 Max Fuel 10w30 for the newest stuff
It can get confusing I may consider going to the 5w40 if the old school Magnum gets dropped
