I talk to my friend that works at a large fleet of trucks cars and vans. He said they use a synthetic blend 15w-40 in everything. Has not had any issues and vehicles sit outdoors some. Anyone here use a 15w-40 in their gas car or truck or van?
I have thought about it. Do you know what he uses - a lot of the 15W-40's have dropped all their gasoline certifications.I talk to my friend that works at a large fleet of trucks cars and vans. He said they use a synthetic blend 15w-40 in everything. Has not had any issues and vehicles sit outdoors some. Anyone here use a 15w-40 in their gas car or truck or van?
The Providence brand 15w-40 by the drumI have thought about it. Do you know what he uses - a lot of the 15W-40's have dropped all their gasoline certifications.
Dunno about the 0w-20 as member HOHN uses it in 2 modern vehicles and he’s in Indiana so it gets somewhat coodYep, have run 15w40 in gassers plenty. Bunch of small block Chevys, a small block Ford, and even my 08 Subaru. A pile of small engines. Forklift at work.
Never an issue, but never ran it in something modern that specs 0w20. Would do more research before doing so.
Depending on winter temp and with the oil options available these days, I'd probably run a 0w40 or 5w40 as an all fleet oil instead.
Providence brand is CK-4 and SNI have thought about it. Do you know what he uses - a lot of the 15W-40's have dropped all their gasoline certifications.
Like I said, more research first. Cst at temp for specific oils I'm considering, what oil does the engine spec in other countries, what have people been doing here successfully, etc.Dunno about the 0w-20 as member HOHN uses it in 2 modern vehicles and he’s in Indiana so it gets somewhat cood
Works out to $2.91 per qt from Rural King before taxes. $640 per 55 gallon drum.The Providence brand 15w-40 by the drum
Same with the ST, I just went and checked the jugs.Providence brand is CK-4 and SN
I ran a lot of 15W-40 in warmer months in my EJ-powered Subarus and mowers. If it gets real cold where you're at 5W or 0W-40 might be better in winter.I talk to my friend that works at a large fleet of trucks cars and vans. He said they use a synthetic blend 15w-40 in everything. Has not had any issues and vehicles sit outdoors some. Anyone here use a 15w-40 in their gas car or truck or van?
$549 if you buy 4+. Never run across this brand before.Here's another 15w-40 syn blend. $599 shipped to your door. $10.89 per gallon / $2.72 per quart.
https://buysinopec.com/products/synthetic-blend-15w40-diesel-engine-oil
Meets Performance Requirements of:
- API CK-4, CJ-4, CI-4 Plus, CI-4, CH-4
- API SN
- Ford WSS-M2C171-F1
- Cummins CES20086, CES20081
- Volvo VDS-4.5, VDS-4
- Detroit Diesel 93K222, 93K218
- Mack EOS-4.5, EO-O, EO-M; Premium Plus 07, Premium Plus 03, Plus
- JASO DH-2
- Renault RLD-4, RLD-3
- ACEA E7/E9
- MB 228.31
- MAN 3575
- Deutz DQC III-10 LA
- CAT ECF-3, ECF-2, ECF-1a, ACEA E7-04 Issue 2 (2007)
- MTU Type 2.1
- PACCAR API CK-4
Here is a VOA of their fully synthetic 15w-40$549 if you buy 4+. Never run across this brand before.
