Anybody familiar with a Timer Module Time Control Unit ?
What this unit does in vehicles : A Nissan Time Control Unit (TCU), commonly called a timer module.
Common Failure Symptoms
If this module fails, you might experience:
  • Interior lights failing to turn off or not turning on at all.
  • Intermittent wipers failing to sweep at set intervals or parking incorrectly.
  • Door locks locking/unlocking erratically.
So what I'm experiencing on my 06 Xtrail (Canada model SUV) is power door locks /key fob not locking -locking.
Rear defroster will not turn on (that is combined with the heated sideview mirrors)
All overhead dome lights will not turn on. (Front map lights/middle dome/rear cargo hatch dome).
No buzzing Alert Warning sound when exiting the vehicle with head lights on.
Everything thing else works as expected. Rear and front wipers works/engine and power windows/heat/etc all good.
My little story: Two weeks ago I decided to brighten up my rear cargo area with a strip of LED 12V strip lights. (I previously did the same thing last year, but under my front dash/light up the foot wells. That went good, no issues.)
I spliced into my two wires for the cargo rear dome light. Had the battery disconnected. Could not get the LED strip to light up . Did all sorts of things to see what I did wrong. Gave up on the splicing into the dome light. I found a rear cargo accessory port (like a cigg lighter socket) and recalled I had something to plug into it. So I spliced two wires into that rear accessory port, hooked up my battery...LED strips lit up nicely.
Then I noticed I had no dome lights. Figured I blew a dome bulb. I happened to have another one on hand. Nope, no light. Then I noticed all three dome lights were off.
Eventually I discovered: No rear defogger function, my power door locks were not functioning , on the door itself and the Nissan key fob. The warning buzzer to remember to turn off headlights not working.
So over the course of the last two weeks I kept Googling/Youtubing what went wrong. Everything pointed to checking the mini fuses under the hood and under the dash. Checked them all , 5 times over. With a test light, with my OBD scanner which has it's own multimeter. Did all the tests with both tools I could find...nothing. I even did two ECU resets, which did nothing. I put in new 10A mini fuses , in the slots marked for rear defroster, Meter/room lamps/ECU...nothing.
I even seen a video saying I could pull my timer control unit, unplug and wait 15-30 minutes. Took the top part of my dash off, found three plugs and unplugged all three....waited....replugged, did ECU drain/battery disconnect.....nothing. Grrrrrrr.
So now I might be looking at having to buy a used or new Time Control Unit.......which I can install myself, but it's the cost involved, going by Google. The part itself might cost me $50-150 used. Or new from Nissan some rediculous price (my guess is $300-500. PLUS I keep reading if I replace that part , Nissan might need to reprogram it .....and whatever Fee they want for that....guessing $150-$250.
What have I not checked? what specific module or relay or fuse could be blown, besides this TCU, that might be a lot cheaper to replace?
I can get by with no dome lights (I have the under dash led strip/my rear led cargo strip working). But I know I will miss the rear defogger/side heated mirrors. The auto door locking/key fob power locks is a big pain in the butt. I cannot even lock my rear hatch, it has no hatch key lock . All I can do is manually lock each of the four doors and set my aftermarket alarm. The rear hatch is unlocked.
You need to get an all data or similar subscription for your car so you can get the wiring diagrams for these circuits to be able to properly diagnose the issue. I am no longer an automotive mechanic so I don’t have access to this information anymore, otherwise I’d gladly look it up for you.
What I can tell you is NEVER wire any aftermarket stuff into a modern cars pre existing circuits like this. If you absolutely have to have these lights operate seamlessly with the dome lights the best thing to do is install a photo cell that will turn them on when the dome light comes on. At the absolute minimum a relay needs to be installed in the dome lights circuit to activate them, they need to draw their power from a second dedicated circuit.
Modern cars are not like older ones and there electrical systems are very sensitive and only designed to work with the factory provided loads. In many cases the systems are Can bus or PWM not constant on off circuits even on something like a lighting circuit. Even EMI from aftermarket accessories that are completely separate from the cars electrical system can wreck havoc with it.
They never sold a Xtrail here nor have I ever looked at one. However I can give you some generic advice on Nissan modules in that they will often tell you they need to be "programmed" but thats not always true.
Anything controlling the key security - usually the ECM and BCM do need to be programmed / vin coded / key coded.
Often later in life Nissan would sell a generic module and program per application - once they were out of production. Basically because there was no firmware loaded. So now the dealer gets to charge for programming also.
For most other stuff if you get the identical part number from a recycler there plug and play. But it must be the IDENTICAL number - not just look the same, because again - could be the same module with different firmware.
good advice...so I called my local Nissan parts dept.
New part is called a Smart entrance Controller. ...$750 plus tax out of Calgary/100 klms away or so.
So forget that.
Parts guy checked with his service tech who was actually familiar with my issue. He said I can get a used part, no need to reprogram that particular part.
I called around a few auto recyclers. One junkyard 30 minutes from me, I texted them photos of mine...$150.
Then I called on a junkyard way the heck out in the far suburbs. (90 minute drive freeway one way) .....told that person what I need...two Xtrails in the yard. ...$20!!!!!.......I used a fuel calculator off Google. (gas is friggin expensive in my city Vancouver Canada...even before Iran kerfuffle)....a return trip of 135 klms to go fetch this part will cost me $26 in regular gas.
I think well worth the drive this Sunday .
And yes. I too read the part must be identical.....mine is a 06 Xtrail.....the far out junkyard is a 05. I have pics and photos on my cell, including the serial number of the Smart entrance Controller. (I removed it last week to see if unplugging it for 30-45 minutes would reset it , as I read it might do that, but it did nothing).
These Xtrails were sold all over the world , except in the USA market. ...Mexico, Canada, Russia, philipines, Thailand, you name it. Unknown in USA, unless you see one with Mexican plates or canadian plates. A very good vehicles with a decent 4x4 system and a Altima 2.5L . Canada only got the 2.5L gas, worldwide it was sold with gas, deisel and even a hi-po turbo 4 cylinder in Japan.
Tons of Xtrail forums online from all the countries.
I bought it in 2015, now 232,000 klms, runs great, clean interior, exterior 85% nice(scratches, dings and dents from previous two owners).Only has 165Hp, 4 speed auto/OD.....but with fresh oil/filter/plugs, clean transmission fluid, upgraded ground wires etc, it zips along pretty good and keeps up with modern SUVs and cars in traffic or the freeway. Not a SUV rocket, but scoots pretty good and gets decent mpgs , as reliable as a used CRV/Rav4.
Having said all this...lol.....no more automotive unicorns for Me!
Tired of hunting down parts for a SUV only sold in Canada for two model years. Rockauto was not bad with stocking some common items. I just want a vehicle that I can walk into or call up my local auto parts store and they have what I need. Like a Rav4 or Corolla.
It's now a 20 year old vehicle, not looking to dump any more big ticket money into it .
If I ever get any big expensive engine or transmission repairs, heck, sell it as a mechanic's special for $500.
As is, worth about $4 to 5K in my local area. Obviously a bit less with electronic glitch I currently have.
So forget that.
Worth the attempt.
Note that there will most likely be a Hitachi number on it also. That may be different. The Nissan number should be specific to the firmware it contains - unless it was replaced at the dealer at some point and the generic module was reprogrammed. Ya clear as mud right :ROFLMAO:
For example - this is one of my ABS controllers. 47660 ZS41C is the number that matters I believe.
I agree to not screw around with the electrical system of the vehicle.
Last year I wired a 24 inch 12V led strip under my dash, directly to the under dash fuse box. Used two 10A mini fuses /fusible link. So far no issues, works great. Two months ago I bought 2 mini pod orange led lights. $8 for two. 12v. My vehicle had the fog lights in the upper trim, my truck just had the fog insert covers if fog lights were not ordered. Drilled a hole in each cover, expoxied my amber led light /wired directly to the front side marker lights for power when headlights are on. Again, so far so good.
Pretty sure when I went to hook up the new led strip to my rear cargo dome light I fried the Smart entrance Controller, cuz everything was working up till that moment.
No more adding any electrical stuff in or out. Hoping I can get this part from my junkyard on Sunday, swap with mine and back to normal.
IF not, ughhh..I guess I live with no rear defogger or power door lock remote function.
Maybe I get another 2-3 years of driving pleasure with this Xtrail, time to retire it and buy another used suv.
Worth the attempt.
thanks for the help, I appreciate it.
Question, if I go buy the junkyard part, assuming numbers match up, but is incorrect.....will I just have the same issues I now have and nothing more? like....I don't want to go plug in the junkyard donor part and fry my ECU , create bigger more expensive problems.
My best worst case scenario, I buy the $20 part, it does nothing . Put back my original fried turd. Keep driving as usual. ---i'm out $20 part plus fuel costs.
I cannot answer this question because I do not know.
I have only ever plugged the correct number, and it worked without reprogramming. But not that module and it was not an Xtrail. I personally would not plug in the wrong number, but thats just me.
I did know a guy on the Xterra forums (as in know on the internet) that claimed he plugged in an ABS module that was not exactly the right number, and his ABS did work but he lost some functionality - like hill start assist and ABLS. Take that as third hand not binding in court, etc.
ok thanks, I will do my best to buy the part with only matching numbers. As I mentioned, I don't want to open another can of worms.
I just want everything to be back as it was, nothing more.
Sorta related , as I was reading how another member on here lost his DLR's on his newer Camry after changing his headlight bulbs......I lost my day time running light function after upgrading to LED bulbs 8-9 years ago.
I do know it's because the DLR function is not compatible with led bulbs, at least in my 2006.
I might have my old halogens in my tool shed, I might go back to the halogens and see if I restore the DLR function.
If so, maybe I look for a good new pair of bright halogens. But halogens seem to burn out too quickly, too sensitive to greasy fingertips. That was why I upgraded this Nissan and my previous Honda to Leds.
Brighter light output, same leds for years, no bulb burnouts.
We see, lol.
@Huskyguy68, X-Trail and X-Terra were great vehicles; good luck to keeping this vehicle alive!
seeeeeeeee...fellow Canadian knowssssss!! lol....I would like to upgrade to a 2014-15 Xterra at some point, but the mpgs kinda suck on that big engine big brother.
I'm getting I think about 20 mpgs City/28 hwy with my 2.5L Xtrail . Auto/AWD .
I had went from my then new 2004 Honda Civic Si 1.7L till 2015, it was not a big shock and hit to the wallet with the Xtrail in 2015, especially getting more cargo+passenger room/AWD/more HP.
BUT....the Xterra might be brutal.
Vancouver has the highest gas prices in North America, has been for years. Currently $1.85 to 1.90. Too be honest, it was around $1.85 to 1.47....bouncing all over the place in 2025. Oct/Nov. it was about $1.61 and we here were sorta happy with that in a defeated -i give up-As good as it gets-attitude. But we know from past gas history prices, it changes with the wind. They gouge us here because they can.
So imagine I buy that Xterra....maybe $1.61-1.67 a liter. Some Saudi prince stubs his toe and the gas here shoots $1.83. Then $1.90.Then $1.95.
''a pipe line somewhere needs maintenance, expect gas to be this high for 2-3 weeks!''...or whatever lie they come up with.
Outside Metro Vancouver, a ten to twelve cents gas surcharge gets dropped . In the metro area, we pay that transit surcharge for Subway/Skytrain extensions, new bridges, freeway expansions, road upgrades. Further out into the middle of the province, it can be 20-30 cents or more per liter cheaper.
So I need to think carefully if I really want that Xterra.
I guess I could Gas and Dash every other fill up. lol.
Xterra (body on frame truck chassis) and X-trail - (unibody FWD bias) have nothing in common besides being made by Nissan and having an X in the name.
We never got the Xtrail in USA. It eventually became the Rogue which we did get.
My Xterra gets 18 on the highway if your very delicate with the throttle. They are getting herder to find. I still have my 2008 bought new. I bought my kid a 2013 after a lot of looking and she has now wrecked it. Were still fighting with insurance over it so I don't know if its coming home or not - its a write off but its all cosmetic and parts are cheap and easy so we shall see.
Unless you want to foray off road I would just keep driving the X-Trail.
I had a coworker who had a nice green Xterra, i think it was 2007.
My cousin also had an Xterra, probably see him tororrow at a birthday party, i ask him how he like his truck. He may of bought the supercharged version, which does not interest me.
One thing i read about the Xtrail and Xterra was a common fatal flaw...mixing of coolant or transmission lines, im sure you are aware of that issue.
Read on some Xterra forum there was a simple fix to avoid that issue before it happens, forgot what it was.
Then i read Nissan apparently fixed that issue in 2011 or 2012.
Even tho i might not really go off road, my city is surrounded by forests, mountains, rivers, ski resorts...so it's nice to think anytime of the year i could go pretty much anywhere.
But i like the Xterra more for the true Trucky aggressive look, roomier, more tank like .
And much more mainstream then my Xtrail, easier to buy parts, or upgrade , personalize.
I know from experience that the Nissan TCU module in the 2009-2013 Cube are largely plug-N-play. I was able to fix the CVT by finding a TCU on eBay with the current firmware, its was less than half the cost of programming.
Each platform / module is going to have it's own specific requirements.
