I would like to use the 32" Polaroid that has a bad tuner. While it is possible to troubleshoot what went wrong I figure it is not worth the time when I can just buy a used ATSC converter.
I know back in the days those government subsidized converters output only SD resolution via RF and in some case RCA. However I would prefer something that can output 720 resolution via RCA (my TV's RF input is dead) and if possible also support clear QAM. As long as it works the cheaper the better, and I will consider used on ebay. I would prefer not to use a dedicate PC running a TV tuner card for complexity and noise reason.
Any suggestion?
Any suggestion?
