Any recent submersible well pump replacement quotes?
We do not get that kind of life out of ours. Usually the motor goes bad. We average 5-7 years out of a pump and motor.
There must be an underlying problem there. Should last at least 12 years. What brand is being used? Is there a voltage problem? Is the pump short cycling? Is it grounded properly? Does it run dry very often? Is there excessive coarse grit coming through?
