Sump Pump Problem..
Why does the pump even need tie down bolts?
Mine just sits in the bottom of the well.
It's got a piece of 2" outlet pipe threaded into it, so it's not like it's going anywhere.
You'll have to look at the picture in the link. I think the weight of the base keeps the pump stable while it's running. And the bolts hold the pump to the base.
I have a couple (Spare) Sump Pumps that looks just like the Rigid.
One is made by Wayne, the other made by Blue Angel.
Although mine have a 'Float' to activate the switch.
I have read other people saying those (3) anchor bolts rust.
I looked thru McMasters-Carrs Catalog and could not find them.
When my Pumps were 'new', I painted those bolts with:
Rustoleum Self Etching Primer & Oil Base paint.
This may buy me a little time.
The current pump I'm using is 11 years old and has those (3) anchor bolts.
I checked it recently and the 3 bolts must be zinc plated and are holding up nicely.
If I wanted to purchase 'replacement bolts', I was going to contact the Pump manufacturer.
Edit: If your Sump Pump ever acts up, you should have a Spare ready to put in.
A spare pump with PVC Pipe & Check Valve attached.
This way it can be changed in seconds.
I have (1) back-up pump (45 year old Pedestal) and (2) Submersibles.
This may be overkill, but I sleep better nights.
Yeah, I was thinking all thread too. Stainless steel would be nice. McMaster has some, you might even be able to get the correct bolts from McMaster.
With those bolts rusting and the pump acting up, could there be a seal in there that got disturbed?
Replace it with another one and fix the current one and use it as a spare as others suggested. You can never have enough of those IMO. The parents lake house has 4 ready to roll.
^+1.....I would replace the current pump, repair this one and use it as an emergency back-up. A failed sump pump is no fun to deal with.
