Spring is here. Finally.
I was washing out the sump hole with a garden hose and the float came off.
The float has a 'steel' rod thru the middle and it was rusting.
I will make a replacement rod using Stainless Steel.
This sump pump is 11 years old and I would like to purchase another
to have on hand for an emergency / next replacement.
This plugs into a 15 amp outlet
Currently: Wayne 1/2 HP ...... 11 years olds.
Has a cast iron base, of coarse it was rusty.
I cleaned it off and it looks decent.
Thinking of: Wayne 3/4 HP, 10 amp
I've been happy with what I have and normally would buy the exact same Model.
Questions: All things being equal, would I regret buying the 3/4 HP ? ? ?
Or should I buy another 1/2 HP ? ? ?
During a heavy rain, the pump will turn on every 2 minutes.
Pumping height is 8 Ft.
Reason for asking is: I know a furnace is sized for the house.
You don't just buy the biggest furnace made.
I don't want to make that mistake with the next pump.
Home Depot sells: Wayne / Rigid / Flotec
If anyone can offer any advise, I would appreciate it.
Thank you.
Larry
Thank you.
Larry
