I've decided to switch over to Redline D6 for the transmission for longer drain/high heat peace of mind. It's currently filled with Valvoline Maxlife, I ordered 12 quarts of Redline D6, which is enough to effectively replace the Valvoline over three drain and fills, however, I'm debating whether I should do all three d&fs in one go (driving around the block to mix it up) or if it'd be fine to stretch them out. Any reason why a GRPIII based fluid would clash with a PAO/POE based?
