E150GT,
I did see those light boxes, and while the t5 would give me the desired color and necessary output, i’m still pretty set on LEDs. Personally, I don’t like an aquarium much past a temp of 10,000-14,000k. Except when I’m stoned, at that point, may as well make everything glow. With that in mind, I like the ability to adjust the red/blue balance with my changing mood.
Hurricanes are frustrating, and you reach a point where having emergency back-up becomes cheaper than replacing $10,000 - $15,000 in livestock. When I was a teenager, we went almost a month or so without power when we became the only home in the area that couldn’t be easily restored. We needed a new pole, and a new pole for one house is bottom-of-the-list type of repairs.
JTK,
I’ve never seen one allowed to just grow up without being affixed to anything. I always glue mine down. I’ll give those lights a look see. I did see the output fades with age, but I also assume that is also related to manufacturer quality. Or I’m wrong, and an LED is an LED. Either way, with replacing a failing LED means a whole new hood, I want to get my monies worth.
Bean,
Most of that stuff is even before my time! Discus were what drew me out of the reef hobby. We had a great breeder by my apartment in Long Beach, so I had my pick of the “not quite perfect” that were off to be killed. I think, more and more, that hobbiests are realizing simple is better. I also feel that tanks age poorly because you lose biodiversity with time. Stronger bacteria survive based on your conditions, take over, and then it’s just a countdown to the end. Because I’m nosy, what to you supplement to get the parameters correct? I’ve alwys used either distilled or ro/di plus equilibrium to being its kH, gH, pH, etc for my cardinals.
LAGA,
I’ll give the JBJs a snoop, thanks! Biocube has a lot of accessories and mods available, which was on my “would like to have” list. Never a big fan of skimmers, but I’d like the absolute to add one later without using a HOB model. LRS is a forum?
