Let me start by saying I'm obviously not an electrician, but I figured this is something with an easy answer. I may not know a lot, but unlike many, I know how NOT to get into trouble with electricity.
I am remodeling my kitchen. The house was built in '61. Previously there was drop ceiling with 8' flourescent lighting. Disgusting. That's all history. Now I am trying to install 4 recessed led lights to the remaining old wiring with a single dimmer.
Details: the old circuit consists of 12/2 romex on a 20 amp breaker. The old switch was removed, however that's what is throwing a wrench in my thought process. When I removed the old switch, there was only one white and one black wire attached. The ground wire was not connected to anything and remained within the wire insulation. Not sure what to make of that. My guess is this is "wired hot" but the dimmer I bought specifically states "do NOT wire hot."
My key question however is how to wire the light "cans" to the old circuit. WAIT, let me explain. I know how to wire them together in parallel. White to white, black to black, and ground to ground. I'll be using 12/2 for these as well. I'm unsure how the circuit is ran (a.k.a. it could be breaker>switch>lights or switch>breaker>lights, etc. But considering the switch only has a single 12/2 attached I'm assuming it is switch>lights>breaker
). With that in mind, how does the first can (the one closest to the junction box) attach to the two 12/2 wires in the junction box?
I'm assuming the same applies? All 3 B-B, W-W, G-G?
I think that's right in "normal" circumstances, but the switch not utilizing a ground is throwing me off.
To help summarize I'll number the questions:
1. Is the lack of ground at the switch ok/normal?
2. Is this circuit "wired hot"?
3. How do the recessed lights attach to 12/2 in junction box?
Sorry for the novel, but i figured more info was helpful. Any help or input is appreciated.
