I have a Trane Weathertron III (?) that was installed in 1985 and this thing seems to require allot of maintenance for some reason. About 3 or 4 times a year the inside coil freezes over because the filter get's clogged. Yes I know your supposed to replace these things once a month whether they need it or not but sometimes I just forget to change it.
I cannot use anything but those thin fiberglass filters in which the size is hard to find at that. The actual size of the coil measures 15" X 19" so I typically just buy a 14X20 filter and break the cardboard corners down so it covers the entire coil. I don't think there is a such a thing as an 15X19 filter since filters don't seen to come in odd number sizes.
I've tried those 3M filtrete filters and those 1/2" thick "cut to size" washable fiberglass mesh filters from Lowe's. Otherwise the coil freezes over due to poor air flow. First of all is this normal that these type of filters would restrict the air flow that much to freeze the coil over? I have a fairly new air handler fan. Could the inside coil itself be restricted and need to be vacuumed or blown off with compressed air?
But here is my main question. I am totally baffled.
Sunday when I got home from work it was in the 30s outside. I went down to my den and noticed no air coming from the vents. HMMM, that's weird, that only happens in the summer when the A/C is switched on. The weird thing was, the house was not that cold. I have a 8500 BTU propane heater in my enclosed carpet and I suppose there was enough heat transfer to keep the rest of the house warm. That is good to know because whenever my heat pump has issues in the winter, I usually switch the ceiling heat on the 3 remaining rooms that the system still works and it actually works quite well despite the fact that heat rises. And also if the power goes out. I have a 7500 watt backup generator which can power just about everything in my house except for my heat pump which is an energy hog.
I went into the basement and noticed the 1/2" pipe exiting the unit had some ice buildup around it. I pulled the panel off to look at the filter. The coil was frozen over but this time the filter was not that dirty. Usually when the coil freezes over, the filter is totally blinded over. But this only happens in the summer when the inside coil is on the "high side" and is cold.
This is a first for me. If the heat-pump is on heat mode, shouldn't the inside coil be on the low side and"hot"? How could the inside coil possibly freeze over in heat mode?
I threw the breakers to the heat-pump, flipped on my ceiling heat breakers and let the coil thaw over nice. Next morning, I installed a new filter, flipped the breakers back on and ever since then the inside coil has yet to freeze over.
Today I was looking around at my outside unit and noticed that sections of the insulation that goes around the 1/2" pipe from the outside unit was gone. Well last time I looked at it back in the summer, the insulated was rotten and a bit crusty looking but was still in tact. The same 1/2" pipe that that had a buildup of ice around it on the inside. So I replaced it with some water pipe insulation and some zip ties. Any chance the deteriorated insulation had anything to do with this?
I can see how the inside coil would freeze up due to poor air flow on A/C mode but how is this possible on "heat" mode since the inside coil should be hot.
Thanks.
Thanks.
