- Joined
- Apr 2, 2021
- Messages
- 12
I was reading RAT 540 oil review and came across his testing of Valvoline Maxlife ATF claiming it is pure junk. I personally have used Maxlife ATF for years and it appears on this site to be well liked. Not sure how RAT 540 says it is so bad.
Here is the link: https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Here are his words: • AUTOMOTIVE – Valvoline MAXLife, Multi-Vehicle ATF, synthetic, for High Mileage Vehicles, red bottle. It was tested several times, as are all oils I test, but this ATF is so poorly formulated, that it IMMEDIATELY SEIZED and FAILED EVERY TIME it was tested, which resulted in a 0 psi value. Of course that “exact same” Engineering Torture Test was used, that every other oil is subjected to here on this Blog. And 99% of all other oils tested do NOT seize, including the five other good performing ATF’s above, that performed just fine. For better or worse, I can only post the test results the way they came out.
This ATF’s performance is so shockingly bad, that I do NOT recommend using it. And most anyone reading this Blog, is probably interested in using what is BEST for their vehicle. So, I suggest selecting from the five other ATF’s above, that all performed well.
