Originally Posted By: ltslimjim
Originally Posted By: 91344George
Cold..
As long as the car was driven for a period of time the night before it was parked to get it up to operating temperature.
Drain stone cold. The nice thing is that when removing the oil filter you don't get any oil flowing out of the filter all over the place. Also you don't burn your hands and arms.
A cold drain allows previously hot oil to fully drain in to the pan.
Combine these two and I would choose to drain cold when possible. The problem is I'd have to park on ramps over night.
If the oil was drained when perhaps came in from work (hot) and left to drain overnight, it would accomplish suspended contaminants draining more freely from hot oil AND the hot oil cooling, into the pan with plug removed, ready for fresh fill in the morning/cold.
Not sure who has that patience anymore, however.
All in all, it is NOT a noticeable amount difference between hot/cold drain, if you let it drain until the slow stream turned to a fast drip and then ~5 more minutes to a slow drip anything beyond that is just nit-picking.
It should also be noted that when the engines were cranked (with the key) they always ended up starting so my mechanic just let the car run for a few seconds before turning it back off. He also mentioned the "get it flowing through the filter, its hot oil" reason. I thought it was a potentially unnecessary step, but i devised a method to incorporate that and fill half the oil capacity, bolt and filter installed, let it run for a few seconds, fill the rest. Perhaps overkill but.. i do use cheap filters..
How recently was that video and what car and filter was it with the primed and unprimed side by side? And do cars really need oil filters primed nowadays?
