Find a link to the "Magnuson-Moss Warranty Act" and read it.
Do you know of ANY filter failure? You're still not getting the point (or at least MY point): if you have Product A made cheaply from cheap components, and Product B made from better, stronger components, and they both cost about the same, why would you waste your money on Product A? It's a simple proposition: I don't need to see a failure to make that decision; I just have to cut open the filters and see for myself. I've done that, and Fram loses, period.quote:
Originally posted by kctom:
QuadDriver
Do you know of a Fram filter failure? I am still waiting. Do you know of a filter manufacturer that has never had one of their filters fail?
I thought I had posted on this way way back.quote:
QuadDriver
Do you remember the condition of the various internal components of the filter?quote:
I watched 2 fram filters burst. and I tore down a motor that had fram filter media nicely packed into al lthe oil passages.
First off, you haven't even addressed my post, most likely because you can't.quote:
QuadDriver
Quite honestly, I do not believe you. If the filter had broken apart and filled the engine with debris, would't you have contacted Fram. Yet you have no horror story to relate about Fram's customer service. Seconly, a disintegrated filter can be caused by a collapsed center tube which is not considered a filter failure.
Concerning the bursting filter; Why would anyone, in his right mind, watch a filter burst, then go and install the same brand again on his engine again, as you relate. Also, a bursting filter almost always happens at maximum RPM thereby destroyiong the engine in the process. Yet you report that your engine survived and you tried it again.
Also, how do we know that excessive oil pressure, not a faulty filter, cased this alleged bursting.
Most of this I have related before.
