Antonio Carraro HYD filter C&P
TN
From the 50 hour service on my tractor
Looks like most hyd filters on the inside, no bypass. Filter media has green hue. There were globs of a white substance that I originally thought was glue. Turns out they have the consistency of vaseline. Perhaps some kind of assembly grease? Thoughts on that?
Little bit of debris here but I had these in the dirt so could be from there
Looks pretty good sir. What fluid and filter went back in and on?
Thank You
Antonio Carraro filters went back on. Cam2 hydraulic fluid. Was done for free by the tractor dealer or I would have used Mobil 424.
I have another filter from this to post soon. probably exactly the same :)
Very good sir, I Thank You 👍🇺🇸
In all the C&P's you have looked at , have you ever seen globs of grease like that? I guess it's grease
Edit: here is the other filter. exactly the same inside including the white globs of something.
1 filter was the hyd supply for the implements and such
1 filter was for the hydrostatic drive
