Anti Sieze On Lug Nuts
Lake Havasu City, Arizona
I know there has been a lot said on this subject one way and the other. I saw yet another example of why to properly lubricate lug nuts yesterday. My neighbor was replacing the tires on his pop up camping trailer. They were cracking and dry rotting from too much UV light exposure. I saw him struggling trying to get both wheels off, and walked over to see if he needed any help.
The lugs were so tight neither of us could move them with the small wrench he was using. He said he never had the wheels off since he bought it. I had some Kroil, and we sprayed all of them and let it sit for a few minutes. Same deal. They wouldn't budge. I had a 1/2" breaker bar with a 6 point socket, and told him it would either break them loose, or else crack them off.
With the breaker bar and a piece of PVC pipe as an extension they started to crack loose, but were snapping and popping for the first half a turn. Every time they did a puff of white corrosive dust came out from around the nut. I kept spraying and forcing them until we luckily got them all off without snapping any of them off. The studs and nuts were all bone dry. When he got back from having the new tires put on, I had a rotary wire brush and cleaned all the studs with my cordless drill. Then blew them off with compressed air, and coated both the threads on the studs, as well as the threads on the nuts, and the tapered seat that meets the wheel with a liberal amount of Loctite C-5 anti seize. They obviously went on much easier then they came off.
I always use anti seize on lug nuts, and have never had this happen. Not even in Chicago through slushy, road salt filled Winters. I've never had a lug nut come loose either. On the other hand, I have seen all but countless people struggle with seized up lug nuts like my neighbor did. So you can put me in the column that believes keeping lug nuts properly lubricated is a definite advantage over leaving them dry.
My biggest concern with lube on lug nuts is over tightening them, especially when they are tightened by a shop using air tools. I lube them but cringe every time I go in for inspection, front end work or new tires. I use as little as possible, less is better in this case. Damed if you do, damed if you don't.
I use it on a stud-by-stud basis if the running torque is rough/high due to corrosion. Open ended lug nuts are worse than the capped ones for this. I make sure to keep it off the acorn surface which provides some of the friction to keep them from backing off.
I do 100% of my work and use a torque wrench (without adjusting for lubed threads). I've still snapped studs. I haven't lost a wheel.
They’re on that tight because of a moron driving an air gun! Somebody hammered em on years ago likely. I’ve had one on so tight before I had to cut 2 nuts off with a torch. Try that one when it’s recessed in an aluminum wheel. That moron stretched the threads so bad you could easily see them bent and I had to replace all the studs.
I’ve lubed all mine for decades and not one ever came loose. I used to use never seize but switched to whatever grease I have on hand. I found the rust belt road gunk seems to stick more to the neverseize and make it sort of waxy and thickened dirty. The grease seems cleaner and coats the threads better for me and cleans up easier with a couple quick swipes with a steel brush.
Of course I don’t use much of either and wipe or wire em off each time before adding a bit more every time I rotate or change mine. Then unlike so many production pros spin mine on with the first setting on my Aircat. After that they get finished up with the breaker bar. So simple when you take a second to do it right.
In that situation maybe a tiny bit on the threads but never on the tapered seat. He better check them frequently if he tows it.
Anti-seeze from my observation can get washed away by road spray. Marine grease would be better. But you can over torque the nut with either.
I typically only lubricate wheel lug nuts on my boat trailer.
The OP is lucky he did not snap any. I have snapped a lug stud and had to get a machine shop to get it out and install heli-coil.
Better would be to spray and use impact. If nogo, then wait a day and spray again and try impact. Impact less likely to snap than a breaker bar.
I always lube my nuts.
Try to keep the lube away from the tapered seat as mentioned above.
I use anti-sieze or often just white lithium grease. I take off 5-10 ft-lbs on the torque wrench to compensate.
I worked on my parents car for the first time. They maintained it exclusively with a local garage. Not a drop of lube, grease or anti-sieze anywhere. What a pita.
I find it funny (ODD funny not Ha-Ha funny) that with all the mechanical sense on this board the instruction, "Anti-Seize acts like a lube so reduce the torque 40% to 50%", isn't common knowledge.
What's the big mystery? Don't yell at me as that isn't the angle I'm coming from.
I do not live in the rust belt , but when I remove a lug nut , I try to spray it & lube it again , when I put it back on .
Tightening it with a 4 way wrench .
Best of luck to you , :-)
There's your sign. What does this have to do with anti-seize? I have a car that has had no anti-seize on the wheel studs for 50 years! But the wheels have been removed occassionally, so nothing is stuck...huh!
This is a good point. Acorn lug nuts keep dirt and water off the threads. Thankfully most cars and trucks have these type of lug nuts today.
In my early working days, I spent about 12 years in the heavy petrochemical world where anti-seize was the order of the day. Many of the environments inside some of the units within these plants was corrosive enough to cause stainless steel to rust and make a Michigan salt-laced winter seem like an oatmeal bath. During one particular maintenance cycle an older fellow and myself had to remove nearly 1,000 stud bolts and 2H nuts from equipment that had been running since the early 1960's (this was 1985 or so). Due to corrosion, more than 50% of the nuts did not have enough hex remaining to use a wrench or socket on them and we were forced to use small pipe wrenches. Smart pipe fitters of the day only applied anti-seize to a nut one side of the stud bolt allowing the other to "freeze" so that you were not unscrewing both sides, thereby speeding maintenance times. Every single one of the nuts that had anti-seize on them broke free with moderate effort and there was still anti-seize visible on the threads.
So when I read things like salt water will wash off anti-seize from lug nuts or the concerns about the over tightening aspect related to use of anti-seize, I find it more than a little comical. Good tire shops use a torque wrench to check the tightness of lug nuts and even with the reduction of friction, you will be fine. I have a metal bottle of anti-seize that I have had since the 1980s that I have always applied to my lug nuts--including those on my trailers. Never once have I twisted one off, never once has one magically loosened, and they always come off without having to use a cheater pipe. I say use the anti-seize and sleep well at night--but to each his or her own.
I would never use anti-seize on studs where the lug nuts spin freely on to the studs, plated to not corrode. On rusty, sticky ones then a little lube is needed. I usually just use a shot of WD40 to free them up. Now, stuck wheels corroded to the hub is a whole different story. That's where a little anti-seize is a must. Rust and corrosion is natures lock-tite.
I always lube them using engine oil.
I never ever ever ever ever ever ever tighten lugs with an air impact.
I always tighten by hand.
WAY too many bad experiences that I never care to repeat ever ever ever again.
If you can't put wheel nuts on with a air gun without screwing things up. You are not much of a mechanic. Always use lube. For the guys who do not use lube. You have never changed a tire on a cattle trailer in the middle of the night.
I kinda wanna hear more stories about ridiculously rusted stuff. Morbid curiosity, I guess.
Pretty much EVERYTHING. If had pulled the nuts and lubed the threads with anti seize when he first got it, they would have come right off. Instead of almost having to risk breaking them off to remove them. (I'm actually surprised I didn't break a couple of them).
