If i might crank this back around to the original study, I have a few questions then a an observation.
Apologies if its been mentioned but:
How many Buick V6's were run on the dyno.
How many 4.3 Caprices were run with each oil.
Were they all the same (gear ratios, transmissions tire diameter and so forth...)
Why are these 2 engines chosen.
What was the purpose of the study ( what did it set out to prove or disprove.)
To determine something like this by sampling you must first define the population (For example 4.3 engines in caprices?, 4.3 engines in general, engines in general), then what you want to sample for and then a confidence level that you want you samples to support.
So for example i want to know if 20W oil does or does not cause more wear than a 30W oil in a 4.3 caprice and i want to be 95% certain that my results accurately predict that. I don't have time to figure the numbers all out but i promise you it is not 10 or 20 cars, its more like 300 or 20W and 300 of 30W. If you want this to cross populations it's probably even more. at some point as long as to population is viable the sample stops rising, that number is probably over 400.
Also my problem with almost all these studies is that they are accelerated in some manner necessarily because if you did this with normal peoples cars it would take 10 years to get results, by which time the results might tbe meaningless. Taxi studies accelerate the testing because they are taxis but is taxi use representative of "normal use". The bus study (IIRC) did it by introducing large amounts of soot or particulate.
So what im saying is that all our UOAs and little test we do don't really mean much, for instance (and we all know this is where this is going) if Ali's Black Label does or does not blow up on 5W that's doesn't prove mine will or wont only that its might.
Now - I'm really sure i'm not about to make any friends here but a goodly portion of what i read here is "I think", "I believe" and "Should be" some of it very eloquently stated and some with some evidence to support it but still... A lot of times 'Should be" Is, and a lot of times what we "think" and "believe" is true, but sometimes not.
