I'm looking to install an oil bypass filter on a 2006 GMC with the Duramax Diesel. Rather than going with the most common install of returning oil to a non pressurized source I'd like to take my oil from the full flow filter dirty side and return the oil to the clean side via the use of a sandwich adapter if one is made or can be modified for this application. Basically one that will have taps for paralleling the full flow filter but not interupt normal flow. I also plan to drill the orifice in the bypass filter outlet to a pre determined size to initiate enough bypass flow under less diffriential. The bypass flow would be initiated via the diff pressure across the full flow filter. BTW the Duramax has a 17 psi internal bypass in the full flow filter. My reasoning for doing this is to relieve some of the bypassing and work load within the full flow filter while not having to rob flow and oil pressure within the system.
Does anyone know if such an adapter is available or is there one that can be modified.
Thanks for any help,
Tommy
Tommy
