Hi, I've been spying on you guys for awhile now & thought I'd ask a question.....some of you guys are very smart.
I'm looking for oil recommendations for my car.....specs are as follows:
1969 Plymouth Barracuda Fastback 340 4-spd.
Engine is .040 over, balanced, flat tapped hydraulic cam, adjustabe roller rockers, steel crank, forged pistons & rods, windage tray, air gap intake, 750 Holley, stainless steel valves, ported heads...blah, blah...all the good stuff....dynoed at 425hp & 480 lb-ft of torque.
I've been using Shell Rotella T 15w40 since I built the engine (6 years ago). Great oil, but I cringe when I start it cold....(75psi oil pressure at idle.....40psi warmed up) I only drive it in the summer. I'd like to go to a 10w-40, possibly Valvoline Maxlife because the rear main is starting to seep oil from sitting all winter. I'd like something to keep the seals & gaskets soft & pliable. I have read all of the concerns with the lower zinc & phosphorus levels in these oils when used with flat tappet cams with high vlave spring pressure. Can i run an additive to bring these levels up (Maxlife makes a seperate additive right....can I combine them?). Or do you guys have another idea? I'd like to stick with a conventional oil because of the low mileage. Would an ester based synthetic soften the seals without causing leaks?
The car is always stored properly in winter & never started. In the summer it is always warmed up fully & driven properly (ie. WOT sometimes : )
Thanks in advance...
