I have a restored 1964 Pontiac GTO with a professionally built 389 ci engine. It is a basically stock, flat-tappet engine which was broken in by the builder. It now has about 1500 miles on the engine. I have been using Swepco 15w40 oil since I received a case of it as a gift from a friend who uses it in his vintage air-cooled Porsche.
I use Mobil 1 oils in all our other vehicles, including 0w40 in the Yamaha four stroke outboard motor. I was considering going with the same 0w40 Mobil 1 oil in the GTO, and maybe add a little ZDDP to be sure the zinc level is in the 1200 ppm "safe level".
Some of the local vintage car club guys are horrified that I would even consider this. The car runs a steady 60 psi oil pressure. Temperatures here are typically 30's in winter and up to 90's in summer.
I would appreciate anyone's thoughts on this. Should I just stay with an oil that appears to work fine in this engine? Why not use the 0w40?
