Another 5000 mile Frantz filter change
Kelowna, BC, Canada
5000 mile filter change, very little material on the magnets. Looks like the Detroit is finally broken in.:)
Have you ever ran a used oil analysis with one of those?
Yes, I've run two vehicles with these and never changed the oil, I'd have to go back and look, but Triton V10 for two years and Cummins 6BT for 2-3 years. Both vehicles got good oil reports back and oil was continued in service without changing. The Cummins was lost in an accident 2 years ago, but I still own the V10. The Detroit is running a Frantz as well, but because I'm running it on 100% used cooking oil, I change the oil every 10,000 miles.
Yes, does this all the time.:) I think 100 psi oil pressure does this.:)
I remember that Scott 1000 you used in a previous post, it compressed down almost an inch and a half with 100 psi, must be the nature of the Kirkland paper to do this instead, I do find that the Kirkland rolls are kind of 'springy' compared to other paper, when I compressed them in a M100.
True, I haven't used the Scott 1000 for some time now, but the Kirkland brand pushes the outer layers up some. I pack them as tight as I can and they still do that.:) It's an enormous amount of force being applied.:)
I may have a theory on this, there is a density change in the roll from being packed tight into the can, there is division between the two, the lower density and higher density of the roll resulting in the movement of the outer layer.
Stop by you local Rona store, a 24 pack of White Swan 1000 1ply is $26, it should still be 4 1/4" in width with a 1.6 center tube the last time I saw it, it's a dense roll that should handle your high pressure feed. :)
I looked on Amazon and they sell Frantz kits now. Looking on Frantz site, the cellulose element is $4.95 and synthetic $10.95. Didn’t see the elements on Amazon. Maybe those are better?
Ive seen it happen a few times. Didnt worry about it. Havent seen it happen in years. I just bought 6 pack of VIVA Signature cloth paper towels. Cut off a 4 1/2 inch element for my filters. Hard to cut with a knife especially the core. Probably use a fine tooth hacksaw and blow off the loose stuff. 4 1/4 inch diameter shouldnt pinch in the Motor Guard. A 5 1/2inch element looks good in the flat head Ford V8 canister filter.
One morning the dispatcher said I have a driver out sick. You will be driving his truck. I crawled up into the truck. The oil pressure didnt come up. 2 cycle Detroit. Go into the office and said there is no oil pressure. The dispatcher said its a Detroit it does not need oil pressure. And you guys are talking about 100 PSI. When Frantz had the 2 3 and 4 stacker the single would have been too small for a diesel.
One morning the dispatcher said I have a driver out sick. You will be driving his truck. I crawled up into the truck. The oil pressure didnt come up. 2 cycle Detroit. Go into the office and said there is no oil pressure. The dispatcher said its a Detroit it does not need oil pressure. And you guys are talking about 100 PSI. When Frantz had the 2 3 and 4 stacker the single would have been too small for a diesel I think on the 8V 71 there was not enough oil pressure to move the gauge. 40 PSI im told is enough when the oil is hot. My oil pump relief valve opens at 60 PSI on the Ford diesel tractor. I would think 100 psi would be extreme on any engine.
I have never seen the paper compress more than 1/2 inch. Thats some ugly paper. I had a Gulf Coast junior bolted to the plastic fan shroud on the 6.9 Ford. It drained good at shut down. I could change it and add a quart of oil in less than a minute. Never went over 2.000. miles. They are gone now The Australian Jackmaster Classic is just as good. In my opinion the Frantz is the messiest design. The Motor Guard needs the right paper.
I hope none of you guys are running these filters with no orifice. Ive had a couple drill out the orifice to get faster filtering. I make orifices by running a 1/8 inch pipe tap into the female end of a 1/4 male pipe to female 1/4 pipe adapter. Put a 1/8 pipe plug in. The one you use a allen wrench to tighten.drill it 1/16 inch.. thats for the black Motor Guard M30. To convert the M 30 to motor oil remove the plastic parts. Press a 2 1/2 inch OD washer on the bottom for a core seal. Put a orifice in the inlet.No core needed with firm paper.
I just measured a Motor Guard factory element. It is 4 1/4 diameter by 4 1/2 inches. I can cut my own elements from VIVA Signature Cloth.. It wont pinch in the gasket.
Bought a few of the cellulose elements in the 80s. I dont think we had Scott 1000 then. They were like todays Scott 1000 with a heavy duty 1 1/2 inch core.
