What happens if I don’t change the bypass filter?
PA
2009 Buick LaCrosse with under 100,000 miles on it. It has an amsoil bypass filter on it. I gave the car to a family in need. They took it in for an oil and filter change. Only the regular engine filter was changed and fresh oil added. The bypass filter was not changed. Will the engine be harmed if they only change the regular oil filter and oil at regular intervals and leave the bypass filter attached and unchanged? Ideally, the bypass filter would be changed or removed, but I need the lowest cost option. Thank you.
Having previously had a bypass filter on my old TDI, it only got changed once every 50-60K miles.
I would say it's probably fine for even longer than that on gassers, since they don't produce soot the way diesels do.
My vote would be change the oil and regular filter, worry about the bypass filter later.
Not sure of miles. Maybe 15,000? Amsoil EADP90 bypass filter down to 2 microns.
I've never used a bypass filter, but it is my understanding that only about a quarter of the oil passes through the bypass filter. Is this correct? So shouldn't bypass filters last a lot longer? I would think that if a bypass filter is changed every second or third oci, it should be fine.
If the bypass filter clogs up, the oil simply won't flow through it. It won't kill your engine.
One of the methods to check that was in the older manuals when I ran them is after running the engine, check the filter to see if it is warm. If it is warm, oil is flowing through it. If the filter and lines remain cold/ambient, it is clogged.
Bouvie
Great work donating a car to a family in need
I've been running a Amsoil Dual Bypass system for 10 yrs
The EABP90, and EABP100 Bypass Filter are able to filter oil for 60,000 and 70,000 miles Respectfully
I exclusively run the EABP100 filters for the extra size and filtering ability.
In Fact I have an extra EABP90 filter that I would gladly donate to your cause
Send a message, and I'll ship it to you.
Good Luck to you!
Bouvie
Good Luck to you!
Wow!! Good on you. Awesome really.
OP has been gone a while - but asking a question:
Some systems use an orifice - but if one was to by a dual remote kit - and screw on one 20-30 micron - side by side with one even finer - would not the basic filter get the lions share of flow and a small portion pass the tighter filter - same effect …
