So I ground something, maybe aluminum unsure. It's the shiny spots in the picture. Will they go away when I grind steel? Hopefully have not ruined it.
This! The wheel will be unbalanced and fracture and fly apart at speed.You ruined it. There "may" be a tool that looks like heel spurs that can clean it, but it would cost more than a new stone.
Using that stone in its current condition will be dangerous.
How can aluminum be crafted to that result? Something just abrasive like sandpaper?Grinding aluminum is usually a NO-NO .
specialty soft metal wheels, flap discsHow can aluminum be crafted to that result? Something just abrasive like sandpaper?
Yep, aluminum is pretty easy to to work with hand tools.How can aluminum be crafted to that result? Something just abrasive like sandpaper?
How thick/thin is that disc? It is already failing, it looks like a cutoff wheel, if that is a thin disc you are lucky it didn't blow up. These are for aluminum..So I ground something, maybe aluminum unsure. It's the shiny spots in the picture. Will they go away when I grind steel? Hopefully have not ruined it.
You really need a "burr", as opposed to a stone. To cut material as opposed to grind it away.How can aluminum be crafted to that result? Something just abrasive like sandpaper?
variable spped grinder?A very good feature of my angle grinder is it's variable speed. If I had a suspect disk like the above I might continue to use it at low speed which would minimise the risk.
never knew. yes big $$$ in comparison.Sure, lots of companies make them usually at a premium price. I bought a Makita 13A variable speed that cost about $200. Bosch has them, Hikoki even have a 120V brushless model.
I am wondering if they are widely available in the USA.My variable speed grinder is a Macallister which is not a premium brand. It was gift so I don't know what it cost. I do know I feel a lot safer using only the speed needed for the job in hand and the reduced gyroscopic effect at low speeds is very noticeable making the tool more controllable.
