I've beat the snot out of several harbor freight angle grinders. I've had to rewire them as the cord broke at the end of the stress relief, and one of them has the locking mechanism to remove the disks compromised, but I have gotten my money's worth from them. I am waiting for the one to die before shopping for another, which will be higher quality.
The last time I used a Makita angle grinder I was impressed how much quieter and smoother it was compared th HF cheapoes. My Friend has an older made in the USA Milwaukee 4.5 inch angle grinder with the variable speed dial, and that it a very nice unit and better suited to what I generally want to use an angle grinder for.
I have a larger older made in the USA Milwaukee 5540 polisher that has a speed control dial as well as a finger trigger speed control. It is kind of the standard surfboard sander/ gloss coat polisher, although Makita and Hitachi have made inroads in this field. I use this for when I need variable speed on 4.5 of 5 inch discs, but it is twice the size and weight as a normal angle grinder and only capable of 2900 rpm IIRC, but give me a 8 inch power pad and some 36 grit paper along with some feathering disc adhesive, and I can make impressive clouds of wood or polyester or epoxy dust.
