Ford thought he was a clever fellow
Used orange dexclone, when he should have used yellow
Now I flush thirty gallons until clear I see
To rid myself of the dexclone looking pee
100K it went, until total destruction
Nearly causing a coolant eruption
Radiator was swapped after a Prestone citric acid flush. This is inside the old radiator (after flush) still with full on additive fallout
It brings a tear to my eye, so beautiful.
In summary, don't follow the 100K recommendation - especially with Ford Orange coolant. Luckily you can exchange the coolant fairly easily idling the engine and draining via the return hose to the de-gas tank using a long vinyl hose and many, many gallons of distilled water. Seeing the final bucket turn clear blue was a relief since several traditional coolant drops with new yellow had seemingly done nothing. This finally turned the tide from orange to yellow since most of the ~4 gallon coolant capacity stays in the system.
Cheers,
SOHC
Cheers,
SOHC
