Originally Posted By: pcfxer
Gotcha'.
I usually say "yes" if I dump the oil and swap the filter out for a new one just to pre-empt OAI's recommendations. I've used the pump as well but the engine was not brought up to a high oil temperature and thus showed 2.6% on gas. I expected this because the gas was never burned off per se.
I've never thought that fuel would cause an oil to THICKEN over time and so I am concerned about the oxidation and oil thickening.
Can you verify whether the coolant system/cooling fans are operating as they should?
Well, the presence of fuel for a prolonged period is definitely causing an environment the oil must react to. Is this a result of nitration or oxidation from the fuel presence, causing to thicken some?
Gotcha'.
