Miles on the SSO 3,593
EAO20 filter
RA300 Filtermag
ISO oil cleanliness code 15/14/12
Particle counts;
>= 2 microns-- 454
>= 5 microns-- 168
>= 10 microns-46
>= 15 microns-18
>= 25 microns-4
>= 50 microns-0
>= 100 microns-0
I didn't expect this test to be as good as it should have been. It was better than if I had no magnetic oil filter at all.
I had a fuel injector wire break. I lost all compression due to severe flooding. I know the oil took a major hit from this.
I had the valves adjusted a couple of weeks after the flooding problem.
Later, the timing belt was replaced, again, the valve cover had
to be removed.
These three events makes this RA300 test other than baseline, although the thought of not having it installed makes me
wonder what could have happened.
The next test is already well underway and I am confident it will be more representitive of the RA300'S capabilities.
