Amsoil SSO 0W-30, 1993 Civic, 3,007 miles
I can see the 3m/3k oci because of the fuel/coolant contamination. You just need a cheaper syn like PP 5q. WM jug @ $20. Save you 50-60 bucks a year. .02.
Harry:
Not to be rude, but SEVEN MPG gain with nothing more than an oil change? I'm not buying it.
The black on your bumper is from the vehicle running rich. If it's gone, this means you are no longer running rich. THIS would likely be the cause of your 7MPG discrepancy.
I have no doubt that the 7MPG variance occurred. Rather my doubt, and quite franky, complete disbelief stems from the fact that you are attributing this to the oil, which is impossible.
Maybe you had a poor connection at the O2 sensor(s) which has since rectified itself perhaps? This sounds far more likely.......
All of what you write can be true. The car, a 1993 Civic DX 1.5 liter automatic transmission was originally stickered at 35 MPG. It now reliably gets 45 MPG plus on the highway.
The soot on the rear bumper was at least partially burned oil.
I attribute the MPG increase to the oil because shortly after going to it, MPG's increased, oil burn stopped, engine ran smoother and much better. I am thinking that the rings are now sealing better and less energy is being wasted as blowby.
Harry:
Just going back here, but I see this:
Originally Posted By: harry j
I'm thinking that I have a leaky fuel injector. I plan to have them all changed soon. The dealer wants $153 each for them, so I'm looking elsewhere for them.
Then:
The engine runs great, idle is a little rough and then there's the gas in the oil, now at 244,000 miles, it is high time by all indications for new injectors.
Then:
On a hunch, I replaced the fuel pressure regulator today. The engine idles much better now. I wonder if a bad FPR was causing the fuel in the SSO. I look forward to the next UOA to see for sure. It may not have been the fuel injectors after all.
Followed by:
As a follow up, the latest UOA shows that the gas intrusion problem has been solved. TBN that had previously been negatively impacted by this issue, now remains at a high level. I recommend that anyone with a Civic that is experiencing gas in their oil, change out the fuel pressure regulator.
THIS would be a very logical explanation as to why you had carbon on your rear valance. And then why it went away. And it also follows my theory of a rich condition, which revealed itself to you in TWO very prominent ways here:
1. Carbon on the rear bumper from an overly-rich fuel mixture
2. Gasoline in your oil from an overly-rich fuel mixture
This would definitely affect your vehicle's fuel mileage.
Harry:
Then:
Then:
Followed by:
Wow! the bashing of Amsoil never stops!
the guy spends time and money with us here and a select few posters here attack the guys credibility.
Well let me throw in my .02 here...
lets hit on the carbon on the rear bumper.
I would say the fact that the carbon on his rear bumper stopped, is for one reason.
I would say that the 3000 mile run that burnt up a quart of oil was left on the back of a civic. simple as that. piston ring packs is where oil does its job or lack of.
I say the Amsoil holds up to 450F temps much, much, longer than dino oil that cakes up and goes out the tailpipie!!!
I love to hear that somebody using the best is getting his money worth in fuel milage alone
LOL LOL LOL!!!
I believe the guy and his 45 mpg civic
Originally Posted By: lazaro
Harry:
Then:
Then:
Followed by:
LOL LOL LOL!!!
Bashing of Amsoil? I'm sorry, but please show me where I am bashing Amsoil? In fact, I'm running Amsoil in my dad's Expedition right now, and have run it for a number of years in Diesel lawn tractors.
I have had great luck with their grease, oil, gear lube...etc.
I simply refuse to believe it can cause a 7 Mpg increase in fuel mileage. Especially when an obvious rich condition, which the OP later rectified with the replacement of the FPR and was documented in this very thread is there as a quite plausible explanation!!!!
He is not bashing Amsoil. You sell Amsoil, so you actually are convincing yourself it's that when you ignored all the facts OVERK1LL just posted.
I don't know of any Honda that will cause any API SM rated oil to "cake up".
If there was sludge/deposits in there, any good synthetic will clean them out in time that could have freed up a few mpg along with all the other changes he made.
I had a 97 Ranger 3.0. Amsoil at 1K and Amsoil gear and trans at 30K. Estimated EPA MPG was 17/21. Started using the Amsoil(TSO) at 72K and with 85-90% highway mileages I was getting 26mpg.
That is the reason I went with the TSO as the fuel savings more than paid for the oil. I don't believe I could have gotten the same results with dino oil. The SSO oil is presently a better built oil than the TSO.
Back to the issue though, harry the oil analysis clearly says you can go a lot further on the oil.
Originally Posted By: buster
harry some oils take time to fully lay down their protective layer. If you are draining oils every 3k and switching brands all the time, that could be one possible reason. .
I agree with this first half
Quote:
I've tried more oils than most people I know and I've never had any difference with engine noise using Mobil 1. However it is possible I guess that some oils will be more quiet than others but generally speaking it's psychological
I cant agree with this half...
your not buying the carbon on the bumper, is oil caking up huh?
Im not ignoring OVERKILLS facts I just dont see where I said Overkill was bashing Amsoil?
you know it just could be possible I have done more oil changes and seen more dirty engines than alot of people in here??
I just threw out over half of my 28 year cast iron collection in the past 4 years about 20 tons worth.
blocks, heads, cranks, etc, etc,
You also have to account for the other things he also changed, which I believe contributed more to the gain. You seem to attribute all of it to the SSO. Why didn't I see any mpg gain in my car?
lazaro:
My belief that it's carbon from gas stems from the fact that the OP said he had fuel dilution in his oil (as shown in the UOA) and the car was running rough!
My Mustang used to blacken the rear valance above the tails if I drove it hard (which I did often). But it used ZERO oil. I imagine it will do the same thing in the Capri body. They run slightly rich at WOT as a safety measure to ward off detonation.
And this is not isolated. My Town Car, when the top-end was swapped, was blackening the rear bumper above the tails. It was rich. I could SMELL it!!! Converting it to mass air got rid of the problem!!!
The symptoms of a rich running engine can be/often are:
- fuel dilution in the oil
- poor fuel economy
- darkened tail pipe
- stains/discolouration on the body around the tailpipe
- rough idle
- noticeable fuel smell to the exhaust odour
He had a number of those symptoms!!! And his two most prominent symptoms (fuel in oil, rough idle) went away after he changed the FPR.
Do you not feel it's the least bit more sensible to attribute the gain in fuel economy (as I said, I'm not doubting the economy figures, simply the means of obtaining them) was due to the rectification of the obvious rich condition with the changing of the FPR, rather than a simple change in oil BRAND?
Stand back for a second and think about this. Think about where I'm coming from here. I harbour no hatred for the product, it's users or it's dealers. I USE the products in question!!
I simply do not agree with you or the OP's interpretation of this scenario.
lazaro:
- poor fuel economy
- rough idle
thanks for the reply, I will agree that much of what you say has merrit.
The variables are many, without tearing into the engine we shall never put our finger on the culprit.
I can see the rings getting carboned up and sticking and allowing fuel to enter the crankcase.
After all there is ring gaps in these engines that will let some fuel pass, but like I said earlier the varibles are multiple here.
bottom line the original poster is having good results period!
now Im having some fun here
may I ask since I cant remember, how long did you use the run of Amsoil? and is that your first run of it?
if yes, let me say stick with the program and you will see gains
I ran SSO 8,500 miles and so no improvement in mpg compared to M1 5w30 EP from a year ago. What I should have compared is M1 0w20 to Amsoil 0w20. Never got around to it.
so for 8500 miles you did get a uoa? was the oil still good? did you put the same type oil back in?
severe service for Amsoil is 15,000 miles not 8,500.
let me ask anyone this question, who knows more about the service life of a engine full of oil? the oil manufacture or the car manufacture?
I rather trust the oil manufacture my opinion here.
and if anything negative happens on your first run of Amsoil do you blame the oil or do you blame the trailing history of the vehicle??
Harry:
Then:
Then:
Followed by:
I first started using the Amsoil 0W-30 when I had 118,000 miles on the car. Shortly after that is when the oil burn stopped. I now have over 251,000 miles and still no oil usage and no black smudge on the bumper.
Buster's opinion is good enough for me. Going from one syn to another syn should make little difference. Certainly, not a double digit % difference!!
Harry:
Then:
Then:
Followed by:
stop saying that stuff! nobody will believe that.
well at least more people will disagree than agree.
you wont win the popular vote.
sounds like your completely brainwashed.
it happened to me too Im in recovery now
lazaro, to this day I have never seen significant mpg differences among different oils of the same grade viscosity whether synthetic or conventional. I'm not saying this can't happen. I'm sure some oils have lower friction and better FM's. I have just not experienced any double digit mpg gain. I've driven over 300k miles in the last 7 years using all different brands of oil.
The issue was why someone would drain an oil at 3k miles that is as expensive and still showing a lot of life left? It then led to mpg claims that were probably due to both the oil and changes he made. I do not believe any oil can improve gas mileage more than 10%. Maybe I'm wrong?
I have to agree with you that the original poster should of left the oil in the car for 6 months longer and 15,000 miles but it's his car, he will cry if he wants too it's his party...
anyway I didn't believe the wild claims years ago either but I followed directions and now I believe those claims are possible.
it's kinda like a crazy dog you have to get rid of cause he bites your drinking buddies====== or you get the dog whisper and he teaches the dog to drink with your buddies.
what is better off in the long run? dead dog or drunk dog?
all depends, so many varibles ...
