I think that would be a good choice!OK I did. A lot going on. Thanks
5W-30 or ??
5W-30 or ??
We are discussing SS above. See other comments. And AMSOIL has been making Group III-based oils for ages, even back when SS was basically just PAO-based plus Group V.The signature series? As far as I have read, it is ASSUMED to be Group 3,4,5. But I’m just assuming the posts that said they were ultimately assuming.
Not sure if assumptions stack up linearly or if there is some type of logarithmic curve.
I know they use G3 in general, but it looks like SS using G3 is an assumption but was also presented as fact. I’ll just go back to waiting for a Voa.We are discussing SS above. See other comments. And AMSOIL has been making Group III-based oils for ages, even back when SS was basically just PAO-based plus Group V.
Similarly, HPL uses Group III in many of their product lines, including the ones they use for the border patrol fleet. It has it place in many lubes, particularly if you aren't trying to blend a 0W-xx.
It's an assumption based on the fact that they call out PAO in the SDS's for some of the grades (it would appear the 0W-xx grades) and don't for others (like 5W-xx and up, where you don't need it). Is this proof positive that they aren't using PAO in the grades with the less stringent Winter grades? No, but it's a reasonable assumption that if they are calling out PAO on the SS 0W-xx grades, the ones they aren't calling it out for is probably because it wasn't used.I know they use G3 in general, but it looks like SS using G3 is an assumption but was also presented as fact. I’ll just go back to waiting for a Voa.
And there was an EU MSDS that showed GTL in AMSOIL SS.It's an assumption based on the fact that they call out PAO in the SDS's for some of the grades (it would appear the 0W-xx grades) and don't for others (like 5W-xx and up, where you don't need it). Is this proof positive that they aren't using PAO in the grades with the less stringent Winter grades? No, but it's a reasonable assumption that if they are calling out PAO on the SS 0W-xx grades, the ones they aren't calling it out for is probably because it wasn't used.
What are these? Made by someone at their request?Amsoil has been known to like "proprietary" esters.
In their FAQ they used to state that they use proprietary esters. Know one knows that but Amsoil and their suppliers. One rumor years ago was Croda but I doubt that is right.What are these? Made by someone at their request?
Good memory on that video. I had seen it before but didn’t remember that quote.
And it's run in a naturally aspirated, port-injected engine. A turbo under load would localize heating in the ring pack area but perhaps would be harder to control for this sequence, which is why they use the Pentastar. Its predecessor, IIIG, was run on a GM 3.8L V6.Also here is something interesting - weight deposit piston average for GF-7 is 4.6. dexos R is 5.4. In 2014 Amsoil SS scored a 7.7. They're claiming an even better score on current formulation that they thought wasn't possible.
Keep in mind this test is just testing the oil's ability to withstand high temperature for a long duration of time. It's not going to throw fuel, cold starts into the mix. The point of the test is strictly heat and time and how long it can resist deposits and oxidation in high temperature situation. (305F for 90 hours).
With all the talk of piston deposits, formation, causes, and how to avoid them, thought it would be relevant to see how they're tested for. In order to evaluate piston deposits and oxidation thickening, the sequence IIIH is used.
https://www.swri.org/sites/default/files/sequence-iiih-test.pdf
Analysis includes visual inspection and:
- Kv increase
- Wear Metals
- Total Base Number
- Total Acid Number
- Oxidation and Nitration.
For GF-6, and now GF-7, the WPD has to be at least 4.2. (higher the better). Unfortunately no change for GF-7.
GF-6 Motor Oils...
- buster
- Forum: Interesting Articles
For sure and it would likely outperform any other oil in that test as well. Amsoil SS pretty much crushes every test you throw at it. Speculating of course but they do make it extremely thermally stable.And it's run in a naturally aspirated, port-injected engine. A turbo under load would localize heating in the ring pack area but perhaps would be harder to control for this sequence, which is why they use the Pentastar. Its predecessor, IIIG, was run on a GM 3.8L V6.
