Does anyone on this board use the amsoil series 2000 0w30? Does anyone believe the "up to" 35k oci. "up to", does it sound like their way out of losing a law suit when some bone-head goes 35k on their corvette oci and the engine devolopes problems?
Yeah, there was no claim that there would be "no wear" over a 35k OCI ...quote:
It will not be a pretty UOA IMO at 35,000 miles but your engine will not seize up either.
For all we know they "use" this for their extended drain claim. Some oils we see shear down .. I'm sure that is probably factored into the factory OCI with the recommended weight. Amsoil probably eliminates that part of the equation.quote:
Too many Jobbers want to try to blame the user for the 0W30 thickening. Amsoil really should admit the problem. Of course some will say that it isn't a problem at all.
***NOTE that claim is based upon having a bypass filter to keep the oil clean.*** So it's constantly filtered to near-new condition.quote:
Actually not true. 35K or one year MAX is based on regular filter changes and top-off and does not require a by-pass filter. Sure it would help, but not required. As others have stated, not too many folks do 35K under 12 months, and if you do it's gotta be long legged highway miles.quote:
An oil which thickens in use is hardly one which is likely to provide long term fuel economy improvements, especially when used for extended drains.quote:
if MPG over 12K is increased it pays for itself
