Engine type: 1.5L (1NZFE) 4-cyl
Miles on car: 48133
First 15K on standard Toyota oil (they did the oil changes)
Then, converted to Amsoil Series 2000 0W-30, which I've been running ever since. This is my second change. I went about 12K on the first batch, but did not get it analyzed.
Months in service: 12
Filtration: Amsoil maximum efficiency filters (don't remember the exact name). No bypass system. Filter was changed with the oil in all oil changes, regardless of interval.
Driving conditions: Hard highway miles. I average 70 to 80 mph on a 70 mile round trip each work day.
Condition of car: Great. No mechanical issues whatsoever.
Approximately 0.5 qt of make up oil added.
Analysis Follows (all in ppm, unless otherwise noted):
Aluminum 6 (3)
Chromium 1
Iron 35 (7)
Copper 9 (2)
Lead 7 (1)
Tin 3
Molybdenum 3
Nickel 2
Manganese 1
Silver 0
Titanium 0
Potassium 4
Boron 10
Silicon 35
Sodium 15
Calcium 2779
Magnesium 188
Phosphorus 723
Zinc 864
Barium 0
PHYSICAL PROPERTIES OF OIL SAMPLE:
SUS Viscosity @ 210 deg F = 65.2
cSt Viscosity @ 100 deg C = 11.67
Flashpoint in deg F = 385
Fuel % = Antifreeze % = 0
Water % = 0
Insolubles % = 0.3
TBN = 1.3
TAN-- no data
ISO Code-- no data
Recommendations from lab:
According to the lab I used, wear was well above average for my Scion. The lab provided averages for all of the various elements above for my motor, based upon an oil run of ~7K. For the elements they flagged as indicative of engine wear, the averages are listed in parenthesis next to the measured value for my sample.
They think 17,135 is too long an interval. They say the values show piston scuffing and excess bearing wear. The TBN was also low at 1.3, indicating that little active additive remained in the oil at the time of the change. Additionally, I need a new air filter.
I have changed the air filter and the oil and oil filter were changed when this sample was collected, so I'm on brand new oil now.
Any comments? Should I change this oil more frequently? Would a 6 month filter change with a bit of make up oil make these numbers better? Are these numbers bad?
Miles on car: 48133
Aluminum 6 (3)
Chromium 1
Iron 35 (7)
Copper 9 (2)
Lead 7 (1)
Tin 3
Molybdenum 3
Nickel 2
Manganese 1
Silver 0
Titanium 0
Potassium 4
Boron 10
Silicon 35
Sodium 15
Calcium 2779
Magnesium 188
Phosphorus 723
Zinc 864
Barium 0
Water % = 0
Insolubles % = 0.3
TBN = 1.3
TAN-- no data
ISO Code-- no data
