Since this is the first extended drain on my SE-R with S2K I question the oil pressure. I have had it in 8 months and prior to changing the oil filter out at 5000 miles the oil pressure would be 25 at idle and 75/80 lbs at higher speed. Now I have about 6500 miles and it goes down to 23/24 ldb at idle and at least 10 lbs higher at high speed. My guess is the AMSOIL is thickening up and at idle I have no idea. Does the oil pressure mean anything anyway.Or is it only in extreams.
